Gamerlingual
Question, on your current FM, it’s also meant to be used on the 1Z?
Thanks, I ordered the case on Amazon but the hard case is hard to find. I’m well aware of Taobao but I hate to use the agents to ship overseas! I will try AliExpress if they have it there. Thanks.
Good to know. Thanks, Mr. Walkman. At this rate, I may recommend these DAPs to friends. They are far ahead of their time. If they have the budget that is.
Dang. So lots more to play with really. When I finish completing my teaching certification training, I’ll really have to dive deep into these modsIt Improves both.
Absolutely. I use my 1Z as transport for my Hugo 2 with the Sony WMC-NWH10 digital cable and with stellar results. This way you can get the very clean digital output stream your WM1A/Z is capable of. You can use the BCR-NWH10 charging/digital output device too but at a higher cost.Amigos, is it possible to connect the NW-WM1x to a Chord Hugo 2 with a digital cable to use the walkman as a transport the the Hugo 2 as a dac / amp?
So 1Z on the cradle to the Hugo? Is that the setup?Absolutely. I use my 1Z as transport for my Hugo 2 with the Sony WMC-NWH10 digital cable and with stellar results. This way you can get the very clean digital output stream your WM1A/Z is capable of. You can use the BCR-NWH10 charging/digital output device too but at a higher cost.
In fact the 1Z is one of the very best digital transport I’ve ever tried.
Remember to engage the DoP output option in the 1A/1Z to enjoy DSD with the Hugo 2. Otherwise the stream will be downconverted to PCM prior to output.
This is actual media photo from Koss, looks like they are very serious about the cutting hair part.
As seen in The Empire Strikes Back
Is that right? That's great news and thank you for confirming it. And in that setup, are you able to turn "direct mode" off in the walkman, engage DSEE HX (or any other feature) and perceive the effects through the Hugo?
Is the 1Z/1A connected to the TA via the Walkman cable a better connection than the Cradle with the 1A/1Z in your opinion?When using the cradle or that USB adapter for USB audio out, effects are not working.
I think the player acts only as a sound data source, not too different than an USB stick for example.
