This is what happens when you have a capable reviewer embarrass themself by judging from specific limited measurements, and not enough experience.
So now he says the best Dap out (S-O-N-Y-!) is not up to par.
This is obvious bias.
There is so, so, so much more to a dap than this, that member
@Sonywalkmanuser is currently posting about and enlightening us.
Showing time and time again, that sony engineers are just simply ahead of the others.
None of this will happen, so your talking about "what if"...
NO ONE is going to evolve to hear 120+DB. Your going to go deaf.
Reality.
NO ONE, is going to waste time making computer sound, that no one will be able to hear (except dogs). Reality.
That is speculation on the reviewers part, basing it on one aspect.
For example Chord doesn't focus on this aspect. They focus and talk about their "Taps".
So to me, this is what I would call "nitpicking" on one specific scenario of measument to come up with an assumption.
Opinion is what it is, ONLY his opinion.
Oh yes he is.
It's rediculously obvious when there is no reasonable explanation.
Yes because although it is a "closed back", that cup is actually not dense, or solid.
It's like a paper so why that big headphones is so deceivingly lightweight, and yes sounds from outside leak right thru it.
Extended listening straight out of the Sony will reveal the Z1r more technically better and resolving, although a different and larger signature.
I have been reading you posting about this issue, but never what's wrong until now.
I was assuming it interfered with sound because those previous posts somehow alluded to something wrong.
Now I understand that it is only because of looking at screen you can get a headache??!!
This is a non issue to majority of users. It's a smaller screen than a phone as well.
So then just dim the screen or turn off.
Nobody is going to stare at the screen for the duration of a song to get a headache.
I would make sure there is enough ambient light in room to offset any of the screen light to bother, if you're sensitive.
Totally disagree...
To me, a very reliable source would mean they own the headphone, and the Sony 1a Dap, and also a good amp.
More power doesn't automatically mean better.
You may get fatigue with the power or the specific (extra) amp sound.
The headphone will sound different for sure.
You may, or may regret it.
You will not gain any more quality than you put in.
This is what happens when you listen to others, instead of listening yourself, or people that own the item.
This is all misunderstanding. If you listened to that "fool", then you would be miserable listening on an AK dap, or not knowing better.
You can't go by gossip & generalizations.
I agree it still good and delicacy this way.
The Z1r is a different animal than the rest like 1a & 1am2. It is very very efficient.
That's depending if you want the full capability of bass impact & control.
Most headphones beninfit, but the Z1r does play very well straight out of the Sony.
My problem is that this headphones has much bass capability, so on an amp the Z1r takes on a monsterous bass character along with a bit more intensity.
It will change the sound character.
If you like it as is, then it's just a choice.
Agreed, but the resolution is the same. Only the lower spectrum changes with more power.
The Z1r is more efficient and sensitive than the other models, so it really works well on balanced.
Yes I agree that is become more monsterous/powerful with amp.
Not perfect for every genre though.
