Please welcome, the...
Region Changer
The Region Changer will change the default region of your WM1A/WM1Z, to the one
of your choice.
As we know, we cannot apply tuning mods made for the Universal region, to a device
from the European region, for example. The Region Changer allows us to change that
default region.
The default region will be reverted with a Factory Reset (that will also erase the hours
played counter), or you can just change the region back with the appropriate package.
I made packages that can be used with the 3.00, 3.01, and the 3.02 firmware versions.
LINK
Enjoy!
