Actually, before the planet edition, some of us have already worked on this UPG to make it work for EU model which seems to be excluded regularly in the custom firmwares. This made me think that the majority of the firmwares were written by people without EU models around
Radiobirdman were Australia’s very first punk band. This album is also noted as one of Australia’s top 50 rock albums of all time. They were released slightly in the USA just as Sire Records were going out of business. In the mid 1990s bands like Green Day were showing this style of music could actually become marketable in the US, thus this album was rereleased again as a remaster. I purchased the original in 1977, but have never heard the CD remaster sound like it does until the 1A to 1Z mod to 1A/Z+ salvaged this one. I’ve never heard this album ever sound this good?
Previously, we couldnt share it because no one could have cracked UPG, but thank you to @MrWalkman
After extraction you will go into the installer just as you would in the earlier modded firmware
After running the updater you will have the first window popped up, click Yes. Then second window popped up, leave it there, do not click on anything yet
You will go into the Data folder and you will see the SWUpdate XML of 645Kb (This is Cerberus tuning), Everyone can integrate this Tuning toward any other Firmware versions if they so desired. You will drag this into the Device folder. Window will ask you if you wanted to replace it, click agreed. Then go back to the Installer of the firmware and proceed
That sounds nice, but are you sure that the XML is not actually loaded only at the Software Update tool's startup? What happens if you start the tool, and then you delete the SWUpdate.xml file and try to proceed with the installation? If nothing happens, then it means that the file is loaded at the startup and then it's not loaded again.
That is true, it could still install even if deleted. That means EU can’t get it to work correctly. There is nothing there I could touch since I don’t have EU Walkman here to hear how it could change the sound. I suppose anyone can goes in there and add up that codes
UPG was not cracked back then, no one really know how the XML does what it did. None of us had EU model either. All of the behavior and changes were all done in blindfold
I’m happy to be a guinea pig for this... the only downside of course is the length of time switching from one to the other... hopefully there is someone here with Audacity or any other similar program that can take an official stance on this.
From his photos - there is a monitor with Windows in Russian From the name also, I suspected.Good for me - I remember some things from school, reading cyryllic i.e.
