Redcarmoose
Yes that’s exactly what I meant.
Cheers!
Is any of all this going to be of relevance to the 1Z or is this purely a project aimed at trying to get the most out of the 1A ?
Either the exe file or UPG file could be opened, or perhaps somehow the firmware could be extracted from the hardware?Unfortunately I won't get into details about that. But I can assure you they are real.
in the early days and were running the firmware before 2.0 you had an amazingly dark signature
Bro. please provide us blindtest between stocked 1Z and 1A with 1Z mode switcher, also to list your listening equipment and song/music.Yes. This is 100% stock 1Z sound on 1A. Nothing added or taken away. It’s not a tuning mod or firmware mod. Sounds sublime.
Do you have open_cmd_here.bat? I can't download it from that site.
So what is the point of getting a WM1Z if the WM1A can be made to sound like it?
I know, but I can't get the file I marked.
This sums up what I was trying to ask. Thanks!In theory it can’t happen. It’s like trying to make something that’s physically different the same with firmware. The sound of these things are a combination of hardware and firmware. Though in the last year our basic understanding of the full intentions of the 1A stock firmware has changed. Many of us simply feel the 1A has never been optimized by Sony. There is an unlocked potential for improvement. Some in this thread have modified their 1A player with both hardware and firmware modifications. Others have found the 1A become closer to the stock 1Z with a simple 30 second aftermarket firmware. But there are sound properties from the 1Z copper case. There are differences in tone due to the 1Z capacitors. The Kimber Kable used in the 1Z makes a change too.
But in the end the 1A has it’s own special sound normally. So if you do believe the stock firmware is holding the 1A back, the solution can be a choice of changing firmware? It can in reality be it’s own enjoyable and charismatic player. The reality we may be understanding though is that a larger section of the 1Z personally came from firmware? That’s to be determined when the masses get this update.
