I owned both units and yes it was rather obvious how much more organic the 1Z is over the 1a.I cannot disagree... took me by surprise first thing this morning... I’m in the same test group as yourself and I have questioned if this is a separate tuning, and have been told it is pure stock...
exciting times!
So nice that you guys can finally experience that without the 1z.
This is the main reason I sold off my desktop dacs and settled with the 1z.. Yes like i mentioned, the key words here are organic, warm and sheer analogue sounding
Goodbye my yggy and Holo-Spring dacs.
They not nowhere as seductive or organic as the Sony.
I plan to do a comparison with some desktop dacs once I upgrade the 1z caps to Kaisie mod.
If I could get a 1a with stock 1z sound, then it would be a lighter to carry unit. Then I would do hardware mods to further elevate and eliminate any hardware advantage. I doubt the resistor difference would matter, only the caps.So what is the point of getting a WM1Z if the WM1A can be made to sound like it?
The solid block of hard copper not matter as much if you use both copper tape shielding and silver internal plate.
Essentially save money, and also have a lighter unit to carry.
That in itself is a huge advantage and motivation to actually sell my 1z and take up a 1A..
Only drawback I see that we forgetting is the built-in memory advantage.
But heck, I would keep 1z home and get a 1a for outside and not have to worry about carrying a 1Z around...
