Nowadays, I make sure that battery stay around 90 to 40 percent charge to insure maximize sound performance.
It may fit perfectly but no good for player if the headphones are wired not balanced inside.Oh. Simply put I’m thinking of using the 4.4mm ended cable from the 1AM2 for the WH-1000XM3, which is where the idea comes from. I’ll see how it sounds. Thanks for that explanation
If it's single ended wiring it will short the negatives together inside.thinking of my WH-1000XM3
Agreed, the perfect fitting cables have no relevance, if the headphones is wired inside single-ended, then it will combine the negatives and so be danger for the Sony wich needs the wires separated, and full balanced inside the headphones wiring.So even though it’s suggested in the cable listing that it would work, the cable would actually ruin the Walkman!
I actually went back to E-Earphone to sample the Z7M2 and Z1R and spent a solid 3 hours using them both. I did a lot of stretching around my neck and back before diving in and finally noticed the little differences. Both offer better sounds for the electric guitar riffs and drums while the Z1R has more of a concert feel to it. After really analyzing the sounds using my Z1, I went back to adjusting the EQ on the Z1 using my WH-1000XM3 while going back to the Direct stock sound on the big cans. I managed to get the ideal EQ to match the sound of them as close as I could. Mission accomplished. Then, I transferred whatever FLAC files I had and changed them into ALAC and adjusted the EQ from the Z1 settings (as close as I could) to the Sony App and virtually got the matching soundstage I wanted. It worked out better than expected and now I can keep using my iPhone 11 Pro in BT mode while using my 1A and 1Z for my 1AM2. People are right that you gotta put in the time to really analyze all the sounds and pitches to understand how the instruments can create that synergy you want out of your cans.It may fit perfectly but no good for player if the headphones are wired not balanced inside.
Hi there. I was referred to you by @Redcarmoose but it says your profile is limited in who can see it. Would it be ok to ask a couple of follow up questions considering your expertise over PM?I felt that Z7M2 has wider soundstage and a deeper bass over the 1AM2.
Tonality wise they sound 95% similar. 1AM2 had abit more midbass boost and slightly brighter.
In the end I picked the 1AM2 as I felt it has a more fun tuning over the more neutral Z7M2.
If you change the model to 1Z, then you will have to use 1Z tunings.
Most of my tunings are for 1A, but some are for 1Z as well, like this one, which I recommend trying: https://drive.google.com/drive/folders/1KlDLzWBSPpOpGLA8vKEbsf8wEaNAgizs?usp=sharing
There is another one in my signature, WM1Z².
So I've noticed that the reason why I was not able to install your Autumn+ tuning to my WM1A(1Z J) was because the WM1Z+JP installer detected my device as U region, even though I set the region to J with the command prompt (scsitool-nwz-v26.exe H: dest_tool set J). Does this mean that even though the command prompt lists my device as J region with the command "scsitool-nwz-v26.exe H: dest_tool get", that my device is actually still U region?
If the original region was one from the Universal variant (like U, MX, E), and then you change the region to one from another variant (like J from JP variant, or CEV, CEW from EU variant), you will still have to install packages for the original variant.
So if your device is Universal by default, that does not change when you change the region. You can use the J region but the device will stay Universal.
Ah ok, it just the region change command just changes the sound signature of the device, and not the actual region. Would I have to reapply the region command change after using any tuning mods or does the region signature stay set?
Because my CD ripper (dbPoweramp) seems a bit fussy with trying to obtain track listings - every now and then I resort to ALAC via iTunes, as the Apple database seems to be very thorough, I can note two things:Then, I transferred whatever FLAC files I had and changed them into ALAC and adjusted the EQ from the Z1 settings (as close as I could) to the Sony App and virtually got the matching soundstage I wanted. It worked out better than expected and now I can keep using my iPhone 11 Pro in BT mode while using my 1A and 1Z for my 1AM2. People are right that you gotta put in the time to really analyze all the sounds and pitches to understand how the instruments can create that synergy you want out of your cans.
I don’t personally like the tone of the ALAC decoder on the WM players, something not as nice to me as using the FLAC one...
Additionally, even if you’ve ripped to ALAC and are using that with BT from your iPhone into the WM, you’ll see it is transcoded into AAC, so even if it does work for you, to save space, just stick with AAC for BT connections out of your iPhone
