I get because dmp is AKM DAC and WM1 are Sonys Smaster
No, the package needs an adjustment to be installable on a 3.02 firmware.
I cant rollback to WM1ANo, the package needs an adjustment to be installable on a 3.02 firmware.
IT SAYS connected model WM1A
Wrote 64 bytes to file (mode 33, )
I am back to DMP-z1 1.02 original from Morbiddeath
Doesn't the 1Az get erased when you put Orion5 on?Orion5 is so totally bang on the money for me, on my 1Az that it isn’t even funny - I can truly say that the only time it sounds bad is when it is a poor recording to begin with... if I were to sum it up in one word, it would either be “effortless” or “organic”... absolutely fantastic combo
I think he meant he has a 1A and switched the model to 1Z. If you load a tuning mod onto another then yes it gets overwritten.Doesn't the 1Az get erased when you put Orion5 on?
That’s what I mean, thank you for clarifying on my behalf @aceedburn - will be clearer when noting this in futureI think he meant he has a 1A and switched the model to 1Z. If you load a tuning mod onto another then yes it gets overwritten.
Do you hear a difference between orion 5 on wm1a firmware vs wm1z firmware on the wm1a?That’s what I mean, thank you for clarifying on my behalf @aceedburn - will be clearer when noting this in future
I can say that I enjoy it more for sure, but being blunt, short of having two 1As with me, one with the A version, the other with the Z, my auditory memory isn’t good enough to play spot the difference...Do you hear a difference between orion 5 on wm1a firmware vs wm1z firmware on the wm1a?
Confusing wording. I know haja
pI can say that I enjoy it more for sure, but being blunt, short of having two 1As with me, one with the A version, the other with the Z, my auditory memory isn’t good enough to play spot the difference...
i would say that it is smoother, more balanced with a more textured bass, but I can’t rule out expectation hype / bias from having WM1Z displayed on the Unit Information screen rather than WM1A.
what I can say, whether or no is that Orion5 for me is an awesome tune
Edit: Larkin Poe - Cure For The Common Cold - this track on its own redefines for me what textured bass can sound like - especially for a portable device! Also how much @RobertP ‘s tune can do for these players
Please do, and confirm for me that it isn’t in my head - to be fair, I’d be shocked if it was!p
Haha placebo effects are real. I guess ill have to experiment it myself.
Another track that has redefined bass for me is Falling Free on the Slor album by Eivør - the plucky little 1A really can shine given the right ingredients!
YouTube won’t do this justice...
