- Jun 22, 2015
https://www.head-fi.org/threads/modifying-wm1z-a.856213/Would it be possible to separate WM1A FW thread from WMA1 thread?
Nope, and we don’t want to. We would like to be buried as much as possibleWould it be possible to separate WM1A FW thread from WMA1 thread?
The WM1x is only wired for TRRR and the GRD is not used.I was wondering whether anyone knows the pinout for 4.4mm Balanced TRRRS jack.
I am thinking of updating my SE audeze cable to balanced using TRRRS, but unable to find the exact pinout.
I am a bit worried if they do something strange like the ground area move inTRRS ones
If anyone has the exact schematics it would he great.
Thanks in advance !
Thank you will have a look. Took me a while to figure out it is easier to search using pentaconn than 4.4mm jack
Ground is not used.
Ground is not used.
I have read an article about balanced and the ground can give a problem but I am not sure it was for 4.4 or 2.5mm.Not by Sony no but others might
Edit:
https://www.headphonesty.com/2019/05/balanced-vs-unbalanced-audio-connections/
where is the system (of the player) can u see the ver of the mod FW? I have just changed mine.. and I sticked to the D1.02 soley to note that this is the beginning of the new fw mod.
