nc8000
Well, I would also have it on Walkman , but that is just me
We both have more music than can fit on the player and want all our music on the player so have to sacrfice some hires.
If it had dual micro SD slot and ample storage, would keep all as isWell, I would also have it on Walkman , but that is just me
Instead of downsampling that extreme why not downsample to 24/88.1 or 24/96 for all source files? That way you get better resolution and save space over the originals. You can also try using a higher compression ratio for FLAC to same space at the expense of battery life.58000+ travks, no slow down. Had t convert all hi-res content to 16/44.1
the SonyNWDestTool download link for windows is 404'd on the rockbox website. can anyone upload a copy somewhere?
In fact level 8 doesn't take much more calculation and battery than level 1. The efficiency difference of flac decompression is almost neglectable. That's the trump card of Flac compression.Instead of downsampling that extreme why not downsample to 24/88.1 or 24/96 for all source files? That way you get better resolution and save space over the originals. You can also try using a higher compression ratio for FLAC to same space at the expense of battery life.
anyone? please? i just want to change my region to J
I'll include it in my shared folder tomorrow.anyone? please? i just want to change my region to J
alright cool, thanks!I'll include it in my shared folder tomorrow.
Just moving to OneDrive, i forgot to include that tool.
DMP Z1 has Dual Slots
After a whole journey with Walkman. Finally my Titan (best of Sony) is going to have the benefits too !!!!
Time to Enjoy the Titan again
No thank you for believing lol! Indeed its a very good fw release special and differentMX3 + 3.00 (modded) sounds so nice! Thank you @Midnstorms for convincing me to change lol very accurate indeed!
only the pdf file and bat appears for me, dropbox says certain files are unavailable in this folder
