nc8000
only the pdf file and bat appears for me, dropbox says certain files are unavailable in this folder
There is an exe file as well
![A1F2F31D-866F-44EC-8990-B66E04C40C4C.jpeg A1F2F31D-866F-44EC-8990-B66E04C40C4C.jpeg](https://cdn.head-fi.org/a/11200898.jpeg)
maybe it wont show it because its an exe?
try Solis and CEVA new firmware is on the horizon?
I just got my fourte black trying J+solstis and U + j3zu.
Solstis sound a little too smooth lol and j3zu to aggressive doing further tests only got 15min so far
I am not selling it...I am just saying that with enough words salad, I can also pull this offAllow me to try and marketing my own special cables that I were thinking about selling for
$1499.
This cables were a products of my endless goals of pursuing sound performances with the Motivations that “everything will effect the sound performances”. There were no corner cutting, even the techniques to solder the joints, the carefully selected plug quality which also play a role in the final end goal of sound performances
1/ The body is infused with Silk fibers for self dampening. This minimizes microphonic sin the cables and also the “ringing effects” of any conductors that is conducting electrical signals
2/ Soft PTFE jacket to allow flexibility and also contribute an additional dampening effects to physical vibrations and microphonics
3/ Purity of Single Crystal Ultra Pure and Oxygen Free Copper. While all quality coppers have to be Oxygen free at the least of 97%. This cables is using OCC casting techniques to not only allowing the oxygen free up to 99.999%, but also allow Mono Crystal structures of the copper. The end results is surpassing the IACS rating and raising the bar for over 101% of conductivity
4/ Solder materials are High quality, and High Fidelity profiles with High Silver content that allow the most fidelity to conduct. It achieves the fidelity that are not easily achieved by the typical meaning of soldering and lead free material
5/ Adopting Litz constructions, or specifically each strand of the multi stands 28 wires are individually insulated with clear Epoxy. This will further guarantees virtually Zero oxygen to penetrate and react to form Oxidized copper, which would result in degradations of conductivity and signal integrity, also degrade sound fidelity
6/ Using Gold plating plugs from the source to the connections of the headphones. It has been known that even plugs quality can carry it own sound signatures. Then over the period of being crazily seeking for even the slightest changes within the systems from building my own amplifiers, Stax systems, countless of other modifications and building devices. It is deemed that HD800S has a typical bright and glares on high spectrum. This sound signature of HD800S and the wires materials has called out for the Synergies with Goldplated plugs to bring out the best Synergies to your HD800S and universally friendly to many systems. Using Pentaconn Goldplated and Stock HD800S Sennheiser authentic plugs
7/ rounded braiding construction were chosen for the best faraday caging effects time self mitigate interferences, which results in a beautiful layering and soundstage improvements over stock cables
This cables will bring a very observable performances that you can hear and witness at the first time auditioning it
Warmth, Dynamic, details, soundstage and layerong
I will be honest with you here
1/ Wires are Norne Audio LiTZ Copper
2/ Braiding is from 4 wires braiding techniques that even any moms with daughter can do
3/ Real authentic Oyaide SS47 solder with my skills applied
4/ Authentic Pentaconn and Furutech plugs
That is it! But the cables has a very real quality. The goals and synergies between wires materials, headphones signatures, plugs were chosen for the above mentioned purposes
Trying to solder litz cable is not easy if you don't have experience. I don't even know how you do it without a solder pot to burn thru all the individual enameled wires. Also the solder points on plugs and connectors are tiny so steady hands are a must LOL!
It has been a long time my “Top references Lady!”
KG T2 with my uniquely build quality, XF2 quads and SR-009
Walkman WM1A as a source out of 4.4mm - Low gain - Max output (firmware and hardware modified)
Interconnect is Litz Cardas wires with Pentaconn and Silverplated XLR connectors
Well, I guess I just have what it takes to enjoy more. The ideas of selling cables for good profits has been trailing me though. But I am not going there
I will just be here and enthusiastically share with everybody what I can find
If you sold a cable with that sort of quality for a reasonable price, you would do well. It’s when I see the big dogs and the “word salad” they use to sell cables for thousands of dollars makes me rage.
I don’t rage at the company, I rage at how people spend their money on that. Hate seeing people get ripped off
