Hello!
So I owned my WM1A for a week now , as a backup to my A&K SP1000, which hi love.
while I really dig its size, weight, system and battery life, I definitely like the WM1A less when it comes to overall sound...feels a bit harsher and it seems to have less weight in the sound material. I love the SP1000 so much...
I have tried J with Jupiter3 and Solis as well, but both felt harsh in the mids and highs, even more so than the stock firmware, to my ears.
Also Solis had a weird distortion in the mids that made it hard for me to raise the volume and I always felt like I needed to lower it (opposite of how I use the SP1000...it's pleasure to bring the volume up occasionally). I am very sensitive to the "bump" around 180hz which I can't stand...
So my question is, which region and firmware would you recommend for me to try in order to obtain something similar to the SP1000 ? I know...I have that already, but I really like that timbre and would like a variation of it in smaller, lighter format with longer battery and less heat
Oh and I am using CA Solaris IEMs with Type E tips.
Thanks in advance for your suggestions!
Love this thread and thank you @Whitigir and @Morbideath for all your work!
