Redcarmoose
Totally agree and that's why I was unpleasantly surprised when I saw the counter was reset by the factory restore process.
Faaactooory Reset? Like when it came from the factory?
Yes, the manufacturer decides what's included in a factory reset and it's quite common to have non-volatile counters/settings not touched by a factory reset process so in these cases it does not literally mean factory with all settings/counters zero'ed out like when it left the factory even though the process might be still be called factory reset or restore in the menu.
I guess what I'm trying to say is that it's not always true that ALL settings and counters are zero'ed out after a factory restore or reset. It varies from device to device and in the case of our WM1 players, Sony chose to zero out the Music Player counter as part of the factory restore process.
I guess I get what your saying except formatting storage and resetting all settings DOES do just exactly that? No? You basically never have to do a factory reset unless of some issue? There are two resets with only one clearing the hour counter? At least this is how I see it?
I have conaisered it now that i have 7000+ hours. But i want also to wait for a next release of a sony TOTL DAP and betterselling my Ahas anyone considered changing the battery on their WM1A/WM1Z ?
the manual says that battery is good for 500 cycles , seeing that i am currently at 3500 hours i believe i must have gone through 150-180 cycles , so i am still good i guess
my local SONY center has batteries and can do the replacement so no worries there
i still get at least 16-20 hours of each cycle which is fine but curious if/when i should probably replace the battery with a new one
thanx for any input here
WM1A vs ZX507 (price no object). Which one is a better buy at 2020? Streaming is a nice bonus for ZX507 though I already have FLAC files of most of my music.
Sound quality aside, ZX-507 does not have DAC function or BT receive mode. It is truly meant to be a stand alone device.
I am curious about the SQ as it is using the new FT caps used in DMP-Z1Sound quality aside, ZX-507 does not have DAC function or BT receive mode. It is truly meant to be a stand alone device.
