SONY NW-WM1Z / WM1A
Status
Not open for further replies.
May 20, 2019 at 9:35 AM Post #28,007 of 45,723
Can you please confirm what $70 tube amp you are using? Thanks
It’s a Musical Fidelity X-Can V1 or V2 if it is the one in the picture. It is an 10-15 year old design but one that lends itself to loads of mods
May 20, 2019 at 9:55 AM Post #28,011 of 45,723
This has probably been discussed already, but do we know if we'll get an update to the WM series later this year? What things would you want in the WM2A and WM2Z (Assuming that's what they'll be called)? I know many dislike the WM port but IMO I don't mind it that much, not to mention if it's switched to USB-C we may no longer get that long battery life we get with Sony DAPs. Just a speculation of mine.
May 20, 2019 at 10:10 AM Post #28,013 of 45,723
Can anyone recommend a small portable amp that takes WM1A to WM1Z or Calyx M levels? Thanks.
I’ve not compared it to the 1Z or the Calyx, but I’ve connected the Monoprice AAA THX to the 1A with great results and the Little Bear B4 Tube amp with good results.
May 20, 2019 at 8:43 PM Post #28,015 of 45,723
So I have been switching back and forth between Direct source, and Direct Source off (but with all DSP options turned off).
Direct source seems to have a higher mid bass response and is lower on microdetails.
Direct source off, is this the Sony house sound?
May 22, 2019 at 6:56 AM Post #28,017 of 45,723
I tried to log-in to the accessory Jack website but they seem to have deleted my account after two years of no purchases or no login. Any ways I created a new one
May 22, 2019 at 7:26 AM Post #28,018 of 45,723
Could somebody please post a very close up pic of the 1A/1Z Pentaconn 4.4 plug? It seems the edge of the Pentaconn plug it’s not perfectly smooth in the Sonys I have had at hand and I want to check it. I have read some posts in this thread confirming this issue with pics showing it but I can’t find them.
Thanks!
May 22, 2019 at 7:33 AM Post #28,019 of 45,723
Thanks!
Here
May 22, 2019 at 7:39 AM Post #28,020 of 45,723
Thanks!
On my 1Z the brass rings on both the 4.4 and 3.5 are probably about 1mm raised above the the top of the player and then the rim of the actual plug holes are again a fraction raised above the brass rings
Status
