Redcarmoose
I have been used ZX300 with Andromeda and Alo litz 4.4mm balance cable. It doesn’t have hiss, sound good.
Now I upgrade to WM1Z. I disappointed because on WM1Z 4.4mm balance port show a lot of background noise. It hurts my ear when I listened for a while. On 3.5mm unbalance port WM1Z it’s less hiss. Is it normally?
How can I fix? Maybe This paring doesn’t match. I think, should I try WM1A next? Anyone using WM1A with Andromeda 4.4mm balance, Are there any hiss?
Or I should go back ZX300 which one perfect match Andromeda on 4.4mm balance port?
Umm..I use many combinations of IEMs (including K10 Encore, a pretty efficient IEM) and multiple upgraded cables with my 1z and I've never heard 'hissing' either from the balanced or single-ended jack. How old is your 1z? Maybe burn-in will help (?).
Well it is strange? I have the Encore too, and no hissing, though I only use it single ended. Everything else 4.4m.
Though everyone has a different hearing potential. I’m not sure I remember anyone ever describing hissing with any IEM with the 1A or 1Z? I wonder what it would be? Though it seems 3.5mm single ended is acceptable for you? So you use an adapter or different 4.4mm cable?
Are you using firmware 3.01?
You know there are high and low gain settings......right?
I would say keep trying other IEMs and cables, as it could have something wrong with the cable. I would bet it’s the cable. If not the cable? Hmmm?
Also take note, the 4.4mm capacitors are unstable until burn-in.
