nc8000
actually 24 bit FLAC is a no go, but 16 bit works
Do you mean that the Sony can’t be used as usb dac to play 24 bit flac ???
He answered to my questionDo you mean that the Sony can’t be used as usb dac to play 24 bit flac ???
Yes it can be used to play 24-Bit as well also DSD up to 11MHzDo you mean that the Sony can’t be used as usb dac to play 24 bit flac ???
Can i use my WM1A as a Bluetooth hands free for receuvung calls,? e. G. To hear better, phone volume and audio quality not good Xperia xa
Tried the ringer but it also couldn't mes from cellphone speakers and from my Z1R's connected to my WM1A
Thanks so then i will connect my Z1R's woth the 3.5mm cable to the XperiaNot really, you would need a microphone for speaking to someone. In theory, you could hear what the other person is saying (if the WM1A is connected via BT to you phone), but they won't be able to hear you.
What about BT DAC? or check apple music config.in the name of frugality aka if you have the correct unlimited plan with Verizon (US for sure) you can get a free sub to apple music. there is only one problem I see. I cannot get Apple Music to play through the WM-1A in USB DAC mode.
Tidal no problem, YouTube no problem, Plex no problem, Apple Music NO MUSIC!!!
Apple what gives? or have I missed something obvious that will leave me red faced?
I hqve a similar problem with windows Microsoft edge no sound and crashes with bsod
