Mal Waldron
- Jan 29, 2017
How many charge cycles needs the battery to offer all it's potential?
None as far as I’m concerned, it was at max right from the start
Enable battery saver mode and you are all set. The last thing you want to do with LiON batteries is frequent charging to 100% and discharging to 0%. There is a finite number of full cycles the battery can do. Battery saver will limit charging to 90% and then you need to recharge when the last battery bar starts blinking. Even the Hugo 2 features a "desktop" mode where it stops charging the battery after you leave it on for 24 hours.
Yes, I'm using battery saver mode. I'm getting around 15-16 hours playing dsd and hd flac files.
I turn it off when I'm not using it. By the way, when I'm charging it turns on, isn't it?
That is very good. I only have 16/44 flac and get about 20 hours play time (about 3 hours every day) plus a weeks stand by per charge to 90% and never fully drain and never turn off and charge every Sunday
WM1Z gets my vote. Heard it with the Utopia and it's magical. And the build quality is stellar.
One of the reasons why I am sticking with Sony is due to their battery performance when powered off. I had a Sony phone that I turned off at 100% charge. I turned it back on 6 months later and battery was at 95%. I have had other brands of devices that would have completely drained in one month or less.
Congratulations, maybe we are not all crazy. Well I forgot to get the remote while in Japan last year; I should have made a written list other than a mental list. I don’t have the option of Amazon.com. I still could get one, but the way I use the dock, it’s always close by. I think the remote only forwards songs and pauses, where I always do more than that. Remember too, you can listen to your computer with the 1A as the DAC using the dock in reverse. Though you maybe have no use as you would just use the TA. But myself, I have one pair of IEMs which is slightly better from the 1Z than the TA. The 1Z has a slightly boosted treble over the TA. But everything else is best from the TA. Just spent a day with the old flagship Z7 headphones, the dock and the TA. Some songs I listen to have a super high frequency drum accent, and the combo somehow is able to reproduce the frequency? The combination is truly high resolution. It can be beat, but requires some serious money to do so.Sorry for the late reply, I was quite busy today.
I didn’t have the chance to test it extensively, but I can tell you you were right. It is certainly an improvement when compared to my NUC server and even the Walkman port on the TA.
A great little thing that cradle is. It’s built and packaged beautifully! I also couldn’t detect any difference in SQ plugged vs unplugged. Not sure whether the cradle needs burning in, we shall see.
I found out about the Walkman remote today, it could be quite handy when the 1A is acting as a server inside the cradle. Do you have one?
Sorry for the late reply, I was quite busy today........
Great photo
Sub out the Sony/Kimber cable for an Axios and one could say you have END GAME
(wash, rinse and repeat with the Utopia/Axios/1Z)
