Wow man, out of the 20 hours I have made thus fur, at least half of it (if not more) was made through the TA. Guess it will take weeks at these rate, maybe even months.
Its been really bugging me since i bought the 1a and tested it side by side with the a45. Why is the a45 louder under similar volumes? And at that it seems like both my zeus and hs1551 are much more properly driven by it than the 1a.
Probably a matter of diferent sound sig and design. Just becsuse they are both from Sony does not mean they have to sound the same or have compareable volume scales
I have a question about bluetooth and controlling the volume on my WM1A. I'm on the latest firmware, and when I connect to a bluetooth speaker, I can't control the volume with the WM1A and have to do it on the speaker. When I connect my iPhone over bluetooth or Airplay, I can control the volume, and it's really frustrating that I can't on my WM1A. I also went into settings, under "Audio Device Connection Settings," and checked "Use Enhanced Mode." The language is a little vague, but it seems to imply that this would allow me to control it. With "Enhanced Mode" on, I can press the volume up/down and a "+" or "-" appears in the upper right of the screen, but it doesn't seem to do anything.
Does anyone understand this and what can I do to control the volume?
Hey guys. I figured this might be the place to ask. I'm trying to find a 4.4mm cable that is angled, has a thin wire and doesn't cost a fortune. This cables seem to stay out of the way better for me.
This one is nice but they don't have angled connectors!
4.4mm angled connectors aren't so common, I haven't seen any cable with one. I know Pentaconn sells one for DIY and, as far as I know, Mussashino uses it in his adapters.
