Redcarmoose
No need to disassemble, there is a picture of the cradle’s main board on the Sony Japan website.
Apparently it uses OS-CON capacitors.
This is a quote from another forum:
“I bought the BCR-NWH10, as well, because the battery drain when using the WMC cable is insane; the battery life drops to around 6-8 hours in digital out mode, from a full charge. The BCR cradle is self-powered, which allows you to play and charge at the same time, not only fixing the battery drain issue but also allowing the connection to DACs that draw too much power.
FWIW the OSCONs in the BCR are for power stability only. They do nothing for the output power, per se. The cradle does tend to improve sound somewhat; I suspect there's a fairly dirty or jittery signal, and the cradle improves this somewhat, also allowing something like a USB decrapifier which tends to improve things further-and make it a really rather good transport, at that point. I haven't done any serious comparisons with my MBP, but I use it a lot on my work rig and felt it was good enough to leave the MBP at home.”
Thank-you for that. Also he does not talk about USB cables making a difference in the connection but using a USB filter. You may find a better cable changes things. The Carbon uses silver for contacts as well as has radio interface shielding which some believe helps get the transfer over better. Though this is all very opinionated as a subject, which is why I still need to do a blind test. In sighted tests the better USB cable makes a difference.
