nc8000
check yourself ex1000 listen direct mode off
103- Se and 101-balanced
the volume is the same
I’m back on 2.0 as 3.0 kept crashing and I didn’t need the new features
for me, 3.0 is very stable and I have never had a problem with crash ... not once
True, and I am not advocating this, just exploring options for anybody who has a setup where they think there may be a benefit to utilizing the 4.4. If it can be done easily (for a DIY'er), then it is worth a try. Never know what you will get. Maybe something worth the effort, maybe not. I personally think it makes more sense to just stay with the WM1x in standalone, and if wanting to feed a higher quality desktop rig, then get one with a balanced input. I'm currently feeding the 3.5 into an Audio Pro Addon Five powered speaker, and it is small and compact, and sounds pretty good. When I get around to it, I'm planning to feed the 3.5 into a PS Audio Sprout. So all moderate, small physical dimensions equipment, to fit onto a desktop.Indeed. However I don’t see why anybody would want to go to all this trouble just to get a single ended signal, why not just use the 3.5 to get that.
Same here and I haven't used an SD card since upgrading firmware. I had suggested earlier that it may have something to do with the SD card interface, but I have no basis to guess why.3.0 I have been using for a month and I have not had any crash, I do not use any sd card
I had one crash early on, but all good since, that is with a 400gb card bursting at the seams (just over 15k tracks).Same here and I haven't used an SD card since upgrading firmware. I had suggested earlier that it may have something to do with the SD card interface, but I have no basis to guess why.
I use my 1A for 2hrs a day in receiver mode (as soon as FW3.0 dropped that convinced me to get this to retire the Shanling M0 that held that duty for a few months) - even if it crashed twice a day, the LDAC convenience and SQ would keep me here.
20-30min crazy! ! 3 min to rebuild the database- 6800 tracksIt takes 20-30 minutes to rebuild the database after a crash so that really is a no go if it crashes ever 2-3 hours playtime
