I may agree with you; maybe better than Phantom but it’s been a while since I listen to it. I am captivated by the sound quality. The treble feels very free, can reach really high, clarity’s and resolution extremely high and I think I may hear things I didn’t even hear with Phantom but needs to check again. Soundstage sounds so open, bass can hit hard; it sounds so open and free
You can buy EX1000 4.4 mm cable on eBay; it’s not optimum but you make with what you have, not the best but it is what it is.
I pay $79.99 for 8 core silver copper mix cable from Ebay
When you plug the DAP into windows, the OS creates a file on the DAP which specifies the full range of its I/O capabilities, right down to the audio resolution. If you are concerned about spyware, then I suggest you think more about the system you attach it to, and start wiping the system with everything after every time you connect to it. Of course at that point the firmware spyware in your motherboard will probably realize you wipe your crap all the time and beacon back to the NSA anyway, so you would just be attracting more attention.
what makes ex1000+1z different is the sense of sound coherence outside of the head,huge wilde soundstage , ( on pf-x-g level )three-dimensional ( on se5ult level ) , it's all the resolution, speed, sound very calm and natural, euphoric and natural vocals ,instrument seperation very good and spread
for me in some respects definitively ex1000 deserves the status of the legend is the iem
from 2010 !!! and until now I have heard nothing much better
I am a happy owner of a 1Z. I upgraded from fw 2.0 to 3.0 since release. I've been enjoying it so much until this morning it ran into the rebooting issue with me. Is there any way to solve that rebooting problem? I am using Windows. All the help will be appreciated.
What I did was to reset to factory settings, reinstall 3.0 and then do another factory reset. So far, the crashes stopped. Let's hope it goes on like this...
for me in some respects definitively ex1000 deserves the status of the legend is the iem from 2010 !!! and until now I have heard nothing much better
