SONY NW-WM1Z / WM1A
post-14529972
Post #24,541 of 31,864
Soundizer
Yes Sony do seem to be the only ones. Perhaps because of their size and market penetration they don’t want to be seen breaking regulations.
As I remember Apple also complied with the iPod
Yes but it was easy to turn off - just go into settings. No need to install didgy third party software not approved by Sony.
post-14529997
Post #24,542 of 31,864
Mrcojocaru
Seattle
Seattle
Also, who makes the Software? How do we know it doesn’t install spyware and other stuff. If it’s free it probably will do.
On your dap? What are they gonna spy on lol. Your music tastes?
Reactions: proedros
post-14530003
Post #24,543 of 31,864
krayzie
Rockbox App.
Any instructions on how to install it and then turn off the volume limit, step by step. I use a Mac Computer..
The posted site for the rockbox app does have step by step instructions and would only make sense to a DOS/Windows user and is already quite straight forward.
Perhaps find a friend or family member with a Windows PC?
BTW I changed mine from region CA to region E to allow for the Sony Bluetooth remote.
post-14530012
Post #24,544 of 31,864
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
Rockbox App.
Can't be done, only works in Windows
post-14530017
Post #24,545 of 31,864
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
You can't remove the EU volume cap in settings, you must run the rockbox tool to change the region.
You don't install anything, just run the tool to change the region of the player
post-14530023
Post #24,546 of 31,864
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
double post
post-14530024
Post #24,547 of 31,864
bflat
San Francisco
San Francisco
Network sniffer that will transmit a copy of all of your home's networking traffic to an external server.
post-14530030
Post #24,548 of 31,864
nc8000
Kalundborg, Denmark
Kalundborg, Denmark
Age
57
It's done by the rockbox community that for many, many years have been fiddeling with daps, making tools and the rockbox operating system as an alternative to the stock software on players including iPods
post-14530054
Post #24,549 of 31,864
krayzie
As opposed to built in spyware which requires no installation from Google M$ and Apple? LMAO!
post-14530063
Post #24,550 of 31,864
Dim666
What do you use as a player to operate the Sony dac on Mac ?
Do you know Audirvana ? Because I can't make both (the dac of WM1A/1Z and Audirvana) Do you have a plan ?
post-14530073
Post #24,551 of 31,864
bflat
San Francisco
San Francisco
Mac OS uses USB Audio 2.0 spec so you don't need anything specific to run the WM1a/z as a DAC. You can set your system audio to the Sony and use iTunes as your player. Audirvana or any other media player will work fine too. I use JRiver without issue.
post-14530097
Post #24,552 of 31,864
Dim666
Oh yes ! But how do you concretely ?
post-14530130
Post #24,553 of 31,864
bflat
San Francisco
San Francisco
1) Update your WM1a/z walkman to firmware 3.0
2) While powered on, connect your walkman to your Mac using the Sony WM-Port to USB cable
3) When walkman asks you if you want USB Mass Storage, go to main menu instead
4) Select DAC mode from main menu
5) DAC should show up under System Preferences as "WALKMAN"
6) Select "WALKMAN" for system sound and/or within your media player options
Reactions: Dim666
post-14530137
Post #24,554 of 31,864
Dim666
Many thanks
post-14530222
Post #24,555 of 31,864
Dim666
...and no it doesn't work
Users Who Are Viewing This Thread (Users: 19, Guests: 27)
