SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
nc8000
You're just not trying hard enough lol
You might have to install FW from another region to remove the cap.
There is only one fw for all regions
nc8000
Hey guys.. Something interesting happened. I downgraded back from 3.0 to 1.2. Bluetooth functionally is still there. I haven't had time to play with it, but as of now I can't find the WM1A on my s9+. And don't worry, the cracked glass is just my screen protector.
That’s to pair with bt headphones or speakers, that has always been there
Malevolint
Oh.. damn lol.That’s to pair with bt headphones or speakers, that has always been there
roses77
- Feb 27, 2016
mmm it since that is perfect for 1Z i wonder if 1A owners are so happy too.. for me its a case of I dont know if I was better or not i miss some of the bass but stage its improved i also feel now Type A low + strings sound more desync... making it a little better
I used some of the settings you suggested the vocals are more forward, not so far away. So none of the bass iits just a much more tighter faster bass, similar to Astell&kern Daps. It has more surround sound stage. It has improved for the genre Rock Music which uses guitars. Overall I like the 3.0 using the vinyl surface noise makes vocals sound more lush with EQ on. To me it sounds warm with customised EQ. I have the WM1Z. Using direct source looses a lot of bass, it sounds thin.
The only problem I have in dac mode it sounds terrible with JRiver media center as it has jumping & clipping in songs. I tried direct source no difference it does the same thing.
bflat
Weird. My comments about DSEE on 3.0 is not right. When I tried it, an old EQ setting was also applied. I thought I had reset the EQ a while ago, but just saw that it was still there.
NaiveSound
- Nov 8, 2015
Bt is louder than local play on 3. 0.i wonder why
Soundizer
- Dec 29, 2015
Thank you. That is way too complicated for me.
My question then is, with the volume limit is it loud enough to drive Sony MDRZ1R HEADPHONES.
gerelmx1986
Like @endlesswaves said, My WM1A had plenty of free space: about 74GB free and no microSD in, so not a single crash as of now
superuser1
What format are the msd cards where the device is crashing?
Mindstorms
Formerly known as Midnstorms
- Oct 24, 2016
could it be that ppl experiencing crashes recieved their walkman on 1.2 or had installed 1.2?
gerelmx1986
mine had 1.0>1.1>1.2>2.0>3.0could it be that ppl experiencing crashes recieved their walkman on 1.2 or had installed 1.2?
linux4ever
I went from 1.2 to 3.0. But I unmounted the sd card (and didn't eject it) and had lots of space on my internal storage.could it be that ppl experiencing crashes recieved their walkman on 1.2 or had installed 1.2?
However DAC isn't working on my MacBook Pro. So far all my other DACs had worked fine on this MacBook pro. I'll have to try it on a windows computer.
auronthas
- May 19, 2017
DAC is not working on my MacBook Pro too. I received email from my local Sony Support team asking me to uninstall and reinstall the firmware 3.0. Will try again, hope it will work.
NaiveSound
- Nov 8, 2015
Those who experienced any problems,has any of you emailed Sony about it
- Status
Total: 12 (members: 0, guests: 12)
