tgrosu
- Dec 21, 2015
If the meter shows 2/3 charge, and you turn off the screen, it shouldn't be fully discharged after 7 hours time. And not to the point that it powers off. Only additional thoughts I can throw in are:
-It is improperly discharging if you are getting the low battery message after the 7 hours. That sounds like a bad battery to me. If you are basing the discharge on the little battery meter, your meter might be miscalibrated.
-On the issue of the unit turning off, you might go to settings and make sure it is not on the shutoff timer, which will turn it off after a chosen period of inactivity.
Thank you!
Regarding your last point I will check, I don't remember seeing this option in the menu. However, even if it would trigger this option, it still should have some juice, which was not the case...
