SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
nc8000
How good, effective or safe is this:
Should be ok provided the cable is a balanced and not a single ended one
gerelmx1986
Lacevos
I thought so..... where did u find that dual adapter? I´m asking assuming that you got it in Mexico....Is the normal 3.5mm plug and not the dual 3.5mm plugs? doesn't loo any good. It looks like Short circuit time
gerelmx1986
The dual adapter was made by @Whitigir and the other cable is one of the sony MUC series cablesI thought so..... where did u find that dual adapter? I´m asking assuming that you got it in Mexico....
gerelmx1986
I got this for my XBA-Z5s http://www.accessoryjack.com/sony-muc-m12nb1-balanced-standard-1-2m-headphone-cable-black.htmlI thought so..... where did u find that dual adapter? I´m asking assuming that you got it in Mexico....
but there are these too
http://www.accessoryjack.com/acoustune-arc03-pentaconn-4-4mm-mmcx-balanced-re-cables-black.html
http://www.accessoryjack.com/acoustune-arc13-pentaconn-4-4mm-mmcx-balanced-re-cables-black.html
Accessory jack ship to mexico with normal mail (npt recommended as they stink) and FEDEX 10-day
This shouldnt be used unless the iem cable is terminated into 3.5 trrs, i think if used with normal 3.5 trs cable it might cause a short circuit.
Guys,
Regar
Guys,
I have put the DAP to a test.
I almost fully charged it yesterday and I put it on the playing sequence (no special audio settings = direct).
It took 20 hours to deplete the battery. This time, I have also followed the sequence of messages given by the battery counter and I would say it was quite accurate (no fast, unexplainable depletion).
Given that, I admit that I am a little bit confused as to what is going on...
What do you mean by, i almost fully charged it
Either you did or did not, charge it till it says FULL,
It takes around 4 hours for me i guess.
But as long as the battery is not full, i think the experiment is not complete .. also that with battery care on or off ? And what kind of library, hi res only or mp3 , mixed ?
tgrosu
- Dec 21, 2015
Dear kingdixon,
Almost full means around 3.5 hours of charge. It didn't say full, so I guess just a little bit and I would have been there.
Battery care: off.
No mp3, just flacs and dsd.
But you're right, I should run the experiment appropriately.
Thanks!
Battery care: off.
Thanks!
Dear kingdixon,
Battery care: off.
Thanks!
Well buddy,
Only dsd and flac, your getting 20 hours with a missing half hour charge, i am pretty sure the battery is fine, according to sony estimations dsd only deplete battery in around 15 hours and flac only around 28 hours, so if your playing both with a 30 min missing battery charge, in average i think it is fine.
Audiophonicalistic
Update on my wm1a repair. Sent it in last week for a faulty 4.4 connector and will have my new replacement in on Tues. Thought it would take a month but only a week. Cant wait.
Hanafuda
- Jan 28, 2007
To those who've run the rockbox destination tool on your WM1(A/Z) to change it to English, what destination code is best? I just opened my Japanese WM1A tonight, it's charging now. I want to make sure playlists and remote control are available. I know this is an issue with the zx300 b/c it doesn't have these features on all models so "E" is the preferred destination instead of "U." Same with the WM1? Or is "U" ok?
krayzie
- Mar 29, 2002
I changed my WM1A from "U" to "E" in order to gain remote control function.
I thought the JDM version has no English menu?
Hanafuda
- Jan 28, 2007
What I needed to know. Thanks!
AFAIK, once I set a new destination (E), it will.
EDIT: Yep. Success.
krayzie
- Mar 29, 2002
When will Sony release the next wm1z/a. Or you know... Their successor
Sony might cook up something for 2019, the 40th anniversary of the Walkman.
However if history repeats itself, usually Sony would go all out during the high noon phase of a product cycle, then they will never top it again as it moves toward the sunset phase. The technology will keep moving but in terms of product grade level it probably has already reached plateau, unless some technological leap happens.
- Status
Total: 7 (members: 0, guests: 7)
