nc8000
ugh... why? That is a bummer.
I don’t know of any player where the internal memory is not soldered to the motherboard.
Venturecraft Valoq. The player reads and boots off a internal microsd card.
Interesting, never heard about that one. According to the spec sheet though it has about 6GB of internal memory plus one microSD slot
That's indeed impressive. You got a lucky unit.Didn't realize i was using BatteryCare ON, still at 90% charge, pretty impressive battery life
I think source direct gives you the best sound, next best soun IMHO is DSEE HX + DC Phase lienarizer and next best SQ is just DSEE HX. The normalizer just compresses dynamic range to make tracks sound louder, not my like.I prefer to listen to the 1z with Direct Source, but I also like the Dynamic Normalizer function. Has anyone noticed a difference in sq between playing with Direct Source, vs turning off the other sound adjustment functions, flat lining the equalizer and just leaving the Dynamic Normalizer on? I'm still playing with these two options. Thanks for your opinions!
Any post-hoc processing affects sound quality. These features (e.g. normalizer, EQ, even DSEE HX) add additional components in signal processing. Usually SQ gets deteriorated to a certain degree, or at least it becomes something different from the original recording. Especially, the normalizer directly manipulate the dynamic range so that loud music gets compressed digitally. This is quite different from adjusting the amplitude gain in analogue domain. That's why I personally do not use any of these processing. Just my 2 cents.I prefer to listen to the 1z with Direct Source, but I also like the Dynamic Normalizer function. Has anyone noticed a difference in sq between playing with Direct Source, vs turning off the other sound adjustment functions, flat lining the equalizer and just leaving the Dynamic Normalizer on? I'm still playing with these two options. Thanks for your opinions!
Any ideas for a pair of headphones to match with the player must be over ear, drives well no high gain 100 + setting and good isolation, cable inputs not a problem as I'll be modding them to 4.4 balanced whatever they are , let me know your thoughts.
