JML
Every once in a while I have issues with AIFF album cover art showing up properly on my Mac (in iTunes and Audirvana, which share the same music data), but not on the WM-1A, even though the images were all properly embedded in the AIFF files using Metadatics or Yate, and showing up in the Mac Finder. These have all been for images not found via iTunes image search for a ripped file, but found via Metadatics or just a web search. The problem, as noted, is likely the file type for the image found online outside of iTunes.
The easiest solution I found was to go into iTunes, get the existing album/track image via File Info's tab for Artwork, copy it to the clipboard, then paste the image into the album's files opened in Metadatics. Or, for a new album/track, instead of saving the image from the web and then embedding that file as the album art, copy the image to your clipboard and then paste the image into the file(s). So it's possible that regardless of your OS, if you copy the image to the clipboard and then paste it back into the files, you may cure the problem because of an image conversion done in the copy/paste routine.
