tompaz909
- Feb 22, 2012
Echo Audio.
Thanks, appreciate it!
Echo Audio.
Don't give up just yet. I tried GIMP (for Windows) and finally got it to work (after not working initially). If you haven't tried this, here were the steps that worked for me.
1) From GIMP main menu, select File, then Open
2) Find the .JPG artwork and Open
3) From GIMIP main menu, select File, then Export As
4) Select the .JPG artwork file (same as in Step 2), and click Export
5) Click Replace in the dialog box
6) Click the "Advanced Options" drop down box
7) Uncheck "Progressive" box
8) Click "Export"
That's it!
Before I tried the above, I was trying to "Save As" and that didn't work.
TSAVJason
Stay updated on The Source AV at their sponsor profile on Head-Fi.
Agree. Will try those for my problematic artwork music files.Very solid contribution to thread
They are sold a replacement parts, you can get them from you local Sony repair centre, not Sony store, if they don't have them in stock, they should be able to order them.How do you get them in the US? Sony US does not carry them.
They are sold as spare parts, so you have to go to the Sony repair centre in Akihabara, and it should take about 2-3 day to arrive for you to collect.Glad the cables worked out in the end. Sorry about the troubles initially.
I didn't know you could buy the caps from Sony!? What do you mean directly? Sony Ginza? I asked Sony at one of the e-earphone shows and the staff at the exhibit told me to call Sony support. Good to see I'm learning from folks overseas about Japan even though I'm here .
Just received my 1Z from Amazon. Impressive device!
Bit strange had to plug the cable first as the battery was flat when I tried to boot it. Thought they all came with a good precharge..
I would say the player is new though, manufacturer sealed packaging and wrapped in protective plastic. Firmware 1.20 was already on it so can't be much older then April this year I guess?
Anybody else had to charge before first use and what charging time with a standard USB charger can I expect to full?
Eager to start using this Damn.. my Z5 will take another week to arrive..
From my understanding, sony DAP are not sealed, they are only wrapped with a plastic clear wrapper with one piece of cellotape on the plastic wrapper which is reusable and resealable, no manufacture has their players with a dead battery out of the box. are you sure it's new and not a returned item.Just received my 1Z from Amazon. Impressive device!
My bad but that's what I meant to say: I got it with the small clear seal on the packaging intact and the DAP in the clear wrapper as you described, not re-used I would say though..
I have little doubt it is a new player but found it strange it had lost it's charge.
Got it charged now and this took a few hours. Not 7 hours though as I read in the WM1 manual I downloaded a full charge would take?
On the Z7 / Z1R cup inputs what actually makes contact the tip and ring + & - and blank sleeve or tip and sleeve etc need to make a cable for someone and using TRS jack's not mono ones so just need the solder points for the jacks, I know it's tip ring (99%) but just a double check.
For me hugo 2 plays louder, much louder and you should A B them with marched volume. Sony is better only losing to hugo 2 when connected to speakers. Of course Chord fan boys will start to cry... but it’s MHO, and several people feels the same.I own a WM1Z and a Hugo 2, for a while also a Mojo that I sold at the beginning of the year.
The Hugo 2 outperform the WM1Z but on the other side it's quite big to travel with, I use it as my desk dac connected to my MacBook Pro, while for traveling without any doubt I prefer the WM1Z, it has more storage than any smartphone and the battery can last for over 20 hours, you'll never get the same performance using a smartphone and a mojo/Hugo.
