SONY NW-WM1Z M2 / WM1A M2
Mar 24, 2022 at 8:55 AM Post #1,276 of 15,795
Mar 24, 2022 at 9:04 AM Post #1,277 of 15,795
From the official manual:
(NW-WM1ZM2 only)
  • This product contains gold plating with purity of about 99.7 % gold. Wipe gently without rubbing strongly when you clean the product. The gold-plated parts are more sensitive than regular plated parts. When you clean the product, Sony recommends working on a tabletop covered with a soft cloth to prevent scratches.
Mar 24, 2022 at 10:59 AM Post #1,278 of 15,795
(NW-WM1ZM2 only)
Durable then !
Mar 24, 2022 at 11:00 AM Post #1,279 of 15,795
Mar 24, 2022 at 11:01 AM Post #1,280 of 15,795
(NW-WM1ZM2 only)
Dry or damp cloth?
Mar 24, 2022 at 11:31 AM Post #1,281 of 15,795
Dry or damp cloth?
  • Clean the player with a soft cloth, such as a cleaning cloth for eyeglasses.
  • To clean a player that has gotten very dirty, use a cloth slightly moistened with a mild detergent solution.
    Be careful not to get water inside the player.
  • Do not clean with solvents such as alcohol, naphtha, or paint thinner. These solvents may damage the surface of the player.
  • Clean the headphone plug occasionally with a soft dry cloth. Noise or sound skipping may occur if the plug is dirty.
https://helpguide.sony.net/dmp/nwwm1m2/v1/en/contents/TP1000464270.html
Mar 24, 2022 at 11:32 AM Post #1,282 of 15,795
Update!
I’ve managed to figure this out with the help of Google and some guy on Reddit.
It appears that a pre-order with Amazon jp can go into some sort of payment limbo. And you need to awaken the order from a slumber of sorts!
I just had to go to “View/Edit order” and then ‘view gift options’. Then in there, just needed to select the (already selected) option for ‘no gift wrapping’ and confirm.
This jolted the order back to life and made it recognise a worldwide Mastercard credit card!
NOW I got an email to say that my bank declined a debit attempt…. but that’s now been put right after a quick call to the bank! 😂
Presumably I’m still getting the item by Wednesday next week.
Turns out I’m getting it nearly £300 cheaper then if I’d gone with Amazon UK.
Got there in the end.
Glad you got it resolved and I hope I rember this if it ever happens to me
Mar 24, 2022 at 2:07 PM Post #1,283 of 15,795
Anyone actually got one of these in their hands yet? When do the pre orders arrive?
As much as I would love to leap up from my A105 I think the wife would disown me if I did…
Anyone went A105-ZX507-NW1AM2 able to comment on the differences?
Mar 24, 2022 at 2:16 PM Post #1,284 of 15,795
Amazon shipped it out today. People in Japan who got it from Sony probably getting it today when the stores open etc.
Mar 24, 2022 at 2:44 PM Post #1,285 of 15,795
It's 10% off at e-earphone
Mar 24, 2022 at 2:46 PM Post #1,286 of 15,795
Anyone planning a YouTube review for any of these? I would like to see some impressions at the very least before I upgrade from my AK Alpha Kann. I only Listen via the MDR-Z1R.
Mar 24, 2022 at 3:36 PM Post #1,289 of 15,795
I posted my impressions of the zx507 vs WM1AM2 in this thread, just a few pages back.
I think the WM1AM2 sounded very similar to the ZX507 in overall sound signature with fast decay and a fun sound but just that the 1AM2 has better dynamics, bigger space and height and more refined imaging.
The WM1ZM2 sounded quite different to the ZX507. The 1ZM2 has a richer tonality, longer decay and a very high dynamic range.
Both the 1AM2 and the 1ZM2 have great sound signature.
If you come from the A105, I think the 1AM2 will be quite a significant improvement especially if you are also going to use the balance 4.4mm. The key difference I feel is the humongous amount of instantaneous dynamics that the 1AM2 improved capacitors can deliver vs A105, considering that the A105 actually uses the same S-Master HX amp as the 1AM2. Bass really goes much deeper on both of the WM1M2.
Mar 24, 2022 at 3:53 PM Post #1,290 of 15,795
How does it compare to the original NW-WM1A?
