linux4ever
WM1A M2 is in stock at Best Buy with free shipping (delivery date Jan 31)
I expect this might be a goldmine for them as the price and Sony name and there’s no more iPods could be a winning combination
and by 10.30pm ET it is out of stock again
So I've been enjoying 1AM2 a lot and thinking about selling it and upgrade to 1ZM2, but now considering to own both instead.
What I have in mind is that 1ZM2 for home use while 1AM2 would be permanently kept and used at work and when travelling.
I'm on the fence coz not sure if 1ZM2 is significantly better than 1AM2 and LPGT which I also enjoy using.
Thoughts?
Yes most definitely. Also I recommend to format the microSD card using the Walkman android settings for the first time before transferring files into the card.Do files still need to be in a Music folder before scanning?
It's too much work, if it scanns all the files ok i guess there's no real benefit from formatting?Yes most definitely. Also I recommend to format the microSD card using the Walkman android settings for the first time before transferring files into the card.
You can also use fdroid + auto app updater for Spotify at least (not sure about other apps). I plan to completely remove play store when I get my AM2. Will probably use the generic android debloat tool which I'm sure is just a script with a bunch of package manager commands so hopefully it's easy to modify it. Also I've been using APKPure and other alternative sources of apps for years and it's all been fine. Maybe I've been lucky.https://www.moon-audio.com/sony-nw-wm1zm2-walkman-music-player-review
I would suggest that you should NOT follow this moon audio article to use APKPure and just stick to Google play store and it’s certified app system:
Reasons:
https://www.hidemytraffic.com/what-is-apkpure-and-is-apkpure-safe/
Risks of Using APKPure
Several risk factors make using APKPure pose a significant danger to its users. While these risks don't mean a definite hack of your device, the threat increases as you download and install more apps from APKPure.
Unrestricted Access to Developers
Unlike the Google Play Store or Apple App Store, APKPure doesn't vet apps comprehensively. It is in APKPure's interest to get as many apps online as possible. While its basic vetting can catch some simple dangers, complex threats online today can easily bypass these checks.
Outdated Apps
APKPure does not always field the newest version of official apps. You can also find some outdated apps or even those of varying versions. The result is that nobody knows for sure if they're getting an app that poses a high risk of security compromise.
APKPure is an Unofficial Source
Since APKPure isn't an official Google source, some primary developers may not list their apps here. There is a risk of third parties uploading hacked versions of authorized apps and masquerading as being the original version.
Poor Security Track Record
Even the APKPure app itself included Malware. Notably, in 2021, APKPure version 3.17.18 came with an advertisement SDK with a Trojan. Several leading cybersecurity companies documented the incident.
At this point in time, I highly doubt Sony will update the OS to 12. Nothing much to be gained. There is also a likelihood that new OS versions can cause issues and bugs. If you look at how Sony Xperia development team does things, they always take a much longer time before their smartphone gets an android version change and usually they are less buggy. My experience with LG updating the android version is not as great, in fact the upgrade caused slowdowns instead of being better, likely the new UI made the gpu worked harder or LG just sucked at optimisation or slowdown the phone to make you buy their new ones but anyway LG is out of the smartphone business all together.wm1zm2 不知道會不會跟上android 12
https://www.reddit.com/r/GooglePixe...urce=share&utm_medium=ios_app&utm_name=iossmf
Not that I'm aware of, no full version number upgrades. I expect NW1AM2/NW1ZM2 to stay at OS 11Have Sony ever performed a major Android version upgrade on their Walkman devices? I don’t remember one for the ZX507/A105 series. Especially seeing as this shares a very similar SOC to that series of systems
Best case for Walkmanmy bents tpu case came in, really well made!
