Sonywalkmanuser
This is a very useful AI tool for getting the actual review score of products on Amazon. give it a try by pasting Amazon product urls:
https://www.fakespot.com/
Metareview is the leading one for filtering the real reviews and real stars of a product.This is a very useful AI tool for getting the actual review score of products on Amazon. give it a try by pasting Amazon product urls:
I've ordered the WM1AM2. Let's see how soon it arrives. I've a k-mod WM1Z, Hiby RS2 (R2R) and Cayin R01 (R2R) to keep me distracted until then
LOLYou must get out and about a lot.
I'm out and about as I'm hearing my RS2 and typing this reply on my smartphoneYou must get out and about a lot.
The app that is responsible for android file transfer to mac/pc is com.android.mtp , so do ensure you don’t disable or uninstall by mistake.I tried to do a full-blown uninstall of android apps, wiping everything listed in the guide, only to realize that my android file transfer also stopped working, so after a factory reset, I stuck to just disabling things. It's more than fast enough if people are wondering unless you plan to use it as a phone,
Yea I went deeper in to the thread and before I knew it play store and file transfer was gone too. I was more focused on getting it done than reading everything lolThe app that is responsible for android file transfer to mac/pc is com.android.mtp , so do ensure you don’t disable or uninstall by mistake.
If you followed my post to uninstall these apps only, you should still be able to use android file transfer
https://www.head-fi.org/threads/son...kman-optimization-guide.962975/#post-16953155
Most version's of Walkman is out of stock Global Logistics700 series is out of stock already
