- Oct 14, 2013
So, basically these Walkman has High-Gain mode. That is physically raising up the amplification voltages from the amp out itself. This is controlled by firmware level.Oh really? Ok, my bad. Makes no sense to gimp the power delivery when they can hard code a software volume cap into the FW. (edit, from a quick google looks like exactly what they did with previous gen)
@Whitigir
Apparently, the volume cap is in the same firmware control policy, that when your unit is volumes capped with this policy in place, you can not enable higher voltage. In the mean while, volume Cap is similar to AVLS (Auto Volume Limiter System). It will not go beyond a certain threshold when set.
I suspect that with Walkman digitally attenuated, and direct digital amplifications, there is some degradation in theory. But I could be wrong. Didn’t the OG 1A/Z received a modified firmware that gives even higher Gain level ?
