SONY NW-WM1Z M2 / WM1A M2
Aug 26, 2022 at 8:37 PM Post #6,031 of 15,741
Has anyone experienced problems trying to update the WM1AM2 firmware to 1.0.2 via wifi? I have a friend who recently bought the WM1AM2 and he can't update because it never goes past the 0% point when he starts the update process.
Aug 26, 2022 at 8:48 PM Post #6,032 of 15,741
nope. updated both my M2s with no issues. Was pretty quick once I was prompted to connect to power while updating.
Aug 27, 2022 at 12:04 AM Post #6,034 of 15,741
Yeah I had low batt so it won't start, but all fine once charged past 50 (I think?) and plugged in. Reboot felt faster haha
Aug 27, 2022 at 3:34 AM Post #6,036 of 15,741
A first for digital music players, listeners can personalize their preferred sound with Sony's DSD Remastering Engine which lets users convert all PCM music sources into DSD 5.6MHz. The DSD Remastering Engine can be switched on or off easily in the user interface.
Aug 27, 2022 at 7:27 AM Post #6,043 of 15,741
Which cable are you using for the EX1000? Looks good. :)
Thank you! They are XBA-Z5's, not EX1000. The cable is a Kbear 16 Core 4.4mm cable, I have no ideal if it is any good, just wanted to try 4.4mm balanced. Not tried the cable on my H3's.
KBEAR MMCX Earphone Cable, 16 Core Oxygen free Copper Balanced HiFi Detachable Extension Cord Replacement IEM Wire for BGVP DM7 DMG TIN T3 T2 (MMCX 4.4mm) https://amzn.eu/d/60VbtV3
I think you can get it quite a bit cheaper elsewhere.
Aug 27, 2022 at 7:42 AM Post #6,044 of 15,741
No, went fine then a long reboot time doing update.
No noticeable difference to me in sound or operation.
Aug 27, 2022 at 8:21 AM Post #6,045 of 15,741
Anyone has trouble to play DSD/dsf files? The two which came with the DAP play well, but many DSD files don't, though they do on PC, Mac and other DAP. Size and MHz limits as described in the manual are met. Meta data incl. art is displayed 🤷🏼‍♂️
