streaming via WiFi?On kkbox high res streaming, dsee on, 88% to 10% last me ar 8hrs. Probably the screen time kill the batt fast.
SONY NW-WM1Z M2 / WM1A M2
AudioAndCoffee
Yes. Still acceptable for me. Cos I am use to charge every day. When batt fail just pay up to replace .. lol.streaming via WiFi?
psikey
- Jul 15, 2008
Yup, I do not think it is the device battery capacityBattery size? (surely must be larger) My Japanese one doesn't show all that.
goody
- Apr 2, 2009
Whats the battery like so far psikey ?...i am also looking to pick one up from japan, just picked up a burson amp this audio business is damn right expensive !!Battery size? (surely must be larger) My Japanese one doesn't show all that.
psikey
- Jul 15, 2008
Massively better than the ZX507 but I'm only listening to my own tracks using the Walkman app since it came yesterday.Whats the battery like so far psikey ?...i am also looking to pick one up from japan, just picked up a burson amp this audio business is damn right expensive !!
My gut feel is its not going to be as good as my Hiby R5GII using the internal DAC/AMP (instead of class A) as that's got monster battery life!
How can I download all song to play offline in Apple Music?I have Hi-Res streaming on. As I mentioned in earlier posts, I don't hear a difference between "Direct" and "DSD Re-Mastering". I prefer having DSEE so I've not used DSD Re-mastering enough to answer your question.
I have Battery Care on, so I always leave the house with 88% charge only. I'm using offline with downloaded Apple Music albums when outside the house, and by my calculations, with my use case (Hi-Res + DSEE on) with IEMs, it should last close to 30hrs.
Streaming would drop that down to around 10-15hrs.
I've not had any issues with the battery life. Definitely less of a worry/hassle than the 3Max I owned previously.
You'll see a down arrow in the top right corner of the album or playlist you're in. But you should go into settings from the main page on Apple Music and choose your download quality first.How can I download all song to play offline in Apple Music?
LouisLoh
- Feb 14, 2011
Any trouble with the ddHifi adapter? I've tried 2 different units, but both had finicky connections. With the slightest touch of the cable/adapter near the connection point, the signal cuts in and out.Yeh! Works with my original remote I had with my ZX300 but didn't work with ZX507/A107
And now listening with my K10U's/silver cable.
I want to download all song in my library, is there any way to do that?You'll see a down arrow in the top right corner of the album or playlist you're in. But you should go into settings from the main page on Apple Music and choose your download quality first.
Add all the songs to a playlist then download the playlist. You can edit the playlist on itune on a computer.I want to download all song in my library, is there any way to do that?
ddHifi specifies that the adaptor isn't meant for WM I believe.Any trouble with the ddHifi adapter? I've tried 2 different units, but both had finicky connections. With the slightest touch of the cable/adapter near the connection point, the signal cuts in and out.
Liono
- Jun 14, 2010
The1Signature
Where can I read that? I didn't find it.ddHifi specifies that the adaptor isn't meant for WM I believe.
psikey
- Jul 15, 2008
No, rock solid, but then I think there are some cheapo copies doing the rounds. Mine wasn't off ebay or Amazon.Any trouble with the ddHifi adapter? I've tried 2 different units, but both had finicky connections. With the slightest touch of the cable/adapter near the connection point, the signal cuts in and out.
I only use it with my solid silver litz cable as its 2.5mm. My Hiby R5GII has 3.5/2.5/4.4 but the Sony just 3.5/4.4
