Sony Australia’s stock ETA’s have changed from 26th April for both 1AM2 & 1ZM2, to 28th June for 1AM2 & 8th August for 1ZM2
Do you have one on order? Hopefully this only affect new orders - not the existing
No I haven’t, I was going to buy one from Minidisc but I ended up getting one from a friend in Japan. I hope you’re right though and it’s only new orders affected.Do you have one on order? Hopefully this only affect new orders - not the existing
yesIs this a proper memory card for the Walkman?
https://www.arrow.com/en/products/mtsd1t0akc7ms-1wt/micron-technology
The only memory card you should be using for your Sony(TM) devicesIs this a proper memory card for the Walkman?
I must say that I would be surprised if anyone heard a difference between a Sandisk or any of these hyper expensive cards. Has anyone done a "listening" comparison?The only memory card you should be using for your Sony(TM) devices
A serious answer, just go get a Samsung or a Sandisk, there really isn't a need to get a MicroSD card meant for a security camera.
Yes there is discussion and impressions further back in this thread within the last couple of weeks (at least I think it is in this thread)I must say that I would be surprised if anyone heard a difference between a Sandisk or any of these hyper expensive cards. Has anyone done a "listening" comparison?
I have not heard @MrWalkman firmwares before, so I am unable to make any comments on its sound quality.@Sonywalkmanuser would you say that it's worth getting the wm1am2 over the original a/z or is it better to get a used z? Don't need streaming, but if the sound is that much better over the mr walkman mods, I can live with android. I'd be pairing with sony m9's.
I've been lurking in the walkman threads forever lol
Good find! At least some of us could have hear the differences , and Sony didn’t lie to us@Whitigir
I found an article which measured the idle power draw of various microSD cards. I guess this is evidence that shows industrial cards have better power management design over consumer cards.
https://goughlui.com/2021/02/27/experiment-microsd-card-power-consumption-spi-performance/
SanDisk Ultra: 1.25mA
Verbatim Premium: 1.45mA
Delkin Devices Industrial card: 0.15mA
The Sandisk Extreme Pro 1tb and Micron 1tb are around $100 difference. Not the end of the world when the Walkman costs close to $4,000 and people spend thousands of dollars on a cable; not me...
Will you believe the words of the current Sony head engineer in charge of Sound Quality of the Walkman division, Mr Sato who has said that he can hear differences in microSD cards? Is he a liar?Good find! At least some of us could have hear the differences , and Sony didn’t lie to us
The thing is the microSD card has physical electrical connection to Walkman. It is a connected component of the audio circuitry. Can the microSD affect the digital audio signals of the Walkman? Well this depends on how much of the electrical noise generated by the microSD electrical components gets into the Walkman’s high precision highly sensitive digital clocking circuitry and how much it affects its signal timing.
We have to look deeper and understand that recreating super accurate sound from digital audio requires very accurately timed data and signalling for the dac to reconstruct into analog signals to the amplifier so as to send the perfectly timed voltage rise or fall to the headphones/iem
More about this:
https://www.soundonsound.com/techniques/digital-myth?amp
