Subhakar
- Nov 26, 2015
Gotta.
I wouldn't say it is a given, I would say close but not better as Sony is using some lower end parts on the A30 than were used on the ZX100.
According to the NW-A30's product page on Sony Malaysia, the retail price will be set to RM899.(Around 215usd)
I think that's the cheapest price compared to prices in other countries.
thanks dudeNW-A30 uses THE SAME OS as WM1 series o WHILE READING THE GUIDE FOR WM1A found these INTERESTING THINGS of the NEW OS
I've read the Guide, my eyes devoured it
SONY FINALLY LISTENED TO ALL OF OUR REQUESTS *
A) you can manage playlists in the walkman Now!!!!!, not just bookmarks
B) You can delete songs, or folders or albums from the walkman now too
C) the EQ looks like kind like parametric
D)you can customize the library screen and hide ítems you don't like f.e (hiding composers view or sensme channels view)
E) in the WM1Z the available space is 230.60GB (my Sammy is 238.60GB) why it is eating so much space? in contrast WM1A is 114.15GB not that much decrease from ZX100
F)during USB connection to pc YOU CAN NOW SELECT DATA TRANSFER & CHARGE (you cannot use the walkman)/ CHARGE ONLY from PC and being able to USE THE WALKMAN
G) Brightness levels has been increased in steps number 0-100 VS 1-5 in ZX100
H) to prevent LOUD volume-surprises when connecting to balanced 4.4mm the walkman will automatically lower the volume
I) it has Keyboard (to search your library)
J) screen will remain off now and to turn it on during playback you must press the power button once (like xperia cellphones)
Volume operation (Only for countries/areas complying with European and Korean Directives
Found these things
some ODD things
EDIT SURPRISE
Walkman NW-A30 series Does not have a DIRECT mode
SUrprise NO. 2 while Reading the NW-A30 guide what the hell?! is there also a Korean volumen cap just like the EU volumen Cap?!![]()
FINAL SURPRISE still doing this?! *File Sizes Larger tan 4GB cannot be playedback
Gosh so I can't combine a couple hundred songs into one massive song over 4 GB in size and play it, sounds like a deal breaker to me.![]()
Do you actually have file sizes larger than 4 GB?
No direct mode, meaning no USB OTG w/ the WM1 cable?
