No I did not use media go. I tried but did not understand how to do the check with that softwareMaybe it could be. Try checking your music library files. Do you use Mediago, Music Center or drag and drop to import music?
SONY NW-A30 SERIES
But other users have not found this problem? for now we are only 2!?
Now, I'm trying to use Media go to transfer all music files on Dap.
Let's see what happens
pinkbecca
- Sep 26, 2014
You can try Ldac sound quality, I think
Odyopile
Does anyone tried MEE PINNACLE P1 to sony a35?plz help
fish1050
LDAC only works with Sony devices so it won't work with your car stereo. I would start with SBC Sound Quality option first. If you are unable to connect or lose the connection then use SBC Connection Preferred.
Wiz33
- Feb 6, 2015
Unless you're willing to change over to this:
https://www.crutchfield.com/p_158RS...a&awnw=g&awcr=86915005825&awdv=c&awug=9032135
- Nov 28, 2016
Now is the time to stock up on these babies. With the newer version out, they retail in Japan for about 16k yen (120€) even at the Sony flagship store on Ginza.
There is a a Sony headphone, with a special cable, one end is WM port and a proprietary looking connector at the phone's base. MDR-1 ADAC.
Zonekiller
120€! In Italy is still between 190/250 €. I can't find a lower price.
16 or 64 GB?120€! In Italy is still between 190/250 €. I can't find a lower price.
Zonekiller
16 or 64 GB?
16 gb (no earphones). Turquoise 195, Black or Pink 209, Red 257!!!
Yes, it's expensive for you.16 gb (no earphones). Turquoise 195, Black or Pink 209, Red 257!!!
Unfortunately the problem has not been solved. I can say that I have tried every solution. I saw the light near the microsd during the block is turned off. Dap or corrupt file?But other users have not found this problem? for now we are only 2!?
- Nov 28, 2016
That's steep.
With the Japanese price you have to consider several factors- weak ¥ vs € and no VAT (there's 8% VAT there, but as a tourist you don't pay it) plus the new version is out so they are getting rid of the old model ("old" - it came out a year ago) so Sony is discounting it by 30% in its own store.
Zonekiller
I Hope they will cut the price here too as far as the new model will be available. Or should I buy it in Amazon.co.jp?
Total: 8 (members: 0, guests: 8)
