SONY NW-A30 SERIES
lesale08
I just reformatted the card and still not read. And nope I just put all the folders in the root of the sd card. No Folder for Music.
music has to be in a folder called music for the NW A35 to see it
superuser1
+1000music has to be in a folder called music for the NW A35 to see it
- Nov 28, 2016
At 100€ the A35 is an absolute steal, go for it!
lesale08
Looks like it is the card that is not being read by the player.
lesale08
I tried all the formats exfat ntfs fat 32 but the dap seems not to read it. It’s just a 64gb card.
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
If you have not already, create a folder on the card called music, then drag and drop the folders with the albums in into that. The sony should then see it. If it doesn't, then grab another card of any size and repeat the process. If THAT card reads it you know this one is faulty. One last thing to try if both of those fail is to use the sony itself to format the card, and then repeat the process with the music folder.I tried all the formats exfat ntfs fat 32 but the dap seems not to read it. It’s just a 64gb card.
lesale08
On the device settings it says no sd card mounted.
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
Right try a reboot, and then reinsert the card and follow the steps above. If that doesn't work it's possible the mp3 player is faulty (is it new?).
lesale08
Thanks for the help. Just a quick question before I sleep as it’s night time here in our place. Does the led indicator inside the card slot light up if there is a card inserted?
Mine does seem to only blink once after I insert the card then it’s gone. I bought this dap used from a friend.
Tomorrow I will also try a different card and see how it goes.
Thanks for all the responses.
it blinks until it has read the card and has creating database on the screen
Odyopile
Good day guys, can anyone suggest me good iem's paired to sony a35? Budget is around 200-250 usd. Im currently using trinity vyrus 2 and co donguri. Thanks
Intensecure
Depends on course on what sound signature you like and what you listen to.can anyone suggest me good iem's paired to sony a35?
But the Sony XBA N3 are fantastic out of the A35. Great pairing.
lesale08
Just an update to my sd card case. Looks like it was my 64gb who’s got a problem. My 16gb card was read perfectly. Now to figure out how to fix my 64gb.
