quartertone
- Apr 5, 2013
Look on the bright side. Now you can mod one!![]()
I have lots of nice colourful tips too.
Could you draw roughly what sort of eq curve this mod would mimick? How much bass cut at what frequencies, etc.? Really curious.
On another note... I'm so on the mh1 bandwagon! haha. I got a pair for $20 just to check them out. Completely blown away! These things are up there with the er4s to me. They are more bassy, but that isn't always a bad thing. First, I simply eq the bass down with ONE single eq point. Second, sometimes it is kind of relaxing and the bass doesn't interfere with the rest of the spectrum as much as on most other iems.
I'll have to check these forums more often.
The frequency response of my "mod" should be similar to that of a dedicated front vent. There are graphs of its effect on Rin Choi's blog. Basically, he drilled a front hole and controlled the leakage with various Knowles dampers. I didn't have a bunch of disposable MH1 samples, so I went with the micro-punctured sleeve instead (this was well before Rin's analysis). It's not perfect because the deep bass response is the first to go. If you make the vent large enough for the mid-bass to be flat (around -10 dB at 100 Hz), you'll hear a very audible roll-off in the bottom octave. It'll graph even worse if you go by Sean Olive's compensation or believe in the missing 6 dB effect. I found a good compromise by keeping the vent small. But I'm the kind of person who insists on getting the mid-range and mid-bass right, even if it means that the response is down a few dB at 30 Hz. To me that's less musical damage than the other way around. Sins of omission vs. commission.
It seems that Rin found a pretty good solution to the excessive bass problem: he decreased the volume of the rear air chamber. Air is a compressible fluid, and if there's less of it behind the driver, the harder it is to move the diaphragm. Since you need more excursion for those really low bass notes, reducing the volume (and thus the acoustic compliance) means that you'll get less bass as well. I'll have to try that trick on some other cheapo IEMs, e.g., Philips 3580.
The way I'm hearing it, the presentation in the upper midrange is different from the ER4S. It's actually closer to the ER4P here. I'm hearing the ER4S pretty much the same as Linkwitz; there's a peak near 2.5 kHz compared to my various sets of speakers. Linkwitz also notes the half-wavelength resonance at 7-10 kHz, which can be addressed by very deep insertion or an absorbent tip like a TX-100. I don't hear that on the MH1 at any insertion depth, even though you can see something that looks like it on Sead's graph in post #211. BTW, the Apple IEM has a sound that's in the same ballpark as a bass-reduced MH1 if you add series resistance with a passive inline volume control and Comply Whoomp tips. I don't listen loud enough for the distortion to be a problem.
I tried the earpods and while I was impressed for a while, once I started hearing the distortion of my pfe112 and knew what to look for, I can't really listen to the earpods anymore. The irony is that I located where the distortion was before even looking at graphs. I always felt the treble of the earpods was distortion free and better than the pfe (distortion wise), but that the sounds was funky somehow. I came to the conclusion that the bass just didn't sound good for some reason. I checked a graph and the bass is where all of the distortion is with the earpods. Interesting.
Anyhow, the mh1 sounds a lot flatter to me than the earpods without modification, although they aren't bad. The mh1 is just smoother and more level end to end. But they do have excess bass. However, you need a lot more eq to really flatten the earpods without resistance, etc.
I insert the mh1 mid ear now, so it reduces treble peaks well and I just eq the bass down. This is a very flat result for me. I'm hesitant to do any mods, because I don't see any that modify only the area of the bass that is problematic...
Hi guys,
as there have been some ongoing discussions related to MH1 mods, here comes some suggestion what can be done to shape and customize the sound according to your own preference.
mod1. If you experience bass being muddy/exaggerated, try to block the vent, this is suppose to reduce the bass ~2-3dB
mod2. if you would like to improve some "airiness" try to remove foam from the tube. However without foam, overall smoothness of the treble will be affected.
mod3 If you would like to get some more presence in the mids, make a small hole (~0.2mm diameter) in the center of the filter mesh. This one require some delicate work, so be careful to not oversize the hole.
Anyhow, these are just some of suggestions what can be done relatively easily to influence certain ranges, however i don't take any responsibilities for your actions, so do it on your own risk!![]()
Yes, i was involved in MH750, and since MH1 and MH750 can be seen as relatives I will mention few words about it. MH750 is a more economical version of MH1 with somewhat slightly different signature as can be seen below...
... most part of the midrange is similar but there are some differences at the lower and upper range. Subbass is slightly higher, while treble roll offs somewhat earlier. So compared to the MH1, overall sound signature of the MH750 can be perceived as slightly darker... further, as there is less energy at the top-end in combination with some more presence in mid-treble will lead to impression of some small treble coloration, and less overall detail compared to MH1.
It is a great iem for the price I paid. I don’t like the flat cable. It’s not very flexible. The sound is nicely balanced, I like the bass, although it’s a bit uncontrolled/muddy sometimes. The mh1’s are for me a bit dull, not very exciting so to say. I grab my KZ zs7 most of the time. If I didn’t have the zs7 I probably take the mh1Quote:
Thanks, I really appreciate your opinion and at the same time i would like to welcome others as well to share their honest views. So guys, feel free to express what you like/dislike around MH1 sound? Actually this is what's all about, to collect all that feedback that will hopefully result in even better sounding products in the future.![]()
Hi ClieOS, i just want to know, as you mention in the one of the post, there are 2 types of MH750 old and new. I have some pairs of MH750 with different type no. One is AG-0501 & other is AG-0500. I tried both type and feel the AG-0501 have more bass and the later little less compared to the former. Is AG-0501 fake or old type?
