Interesting I just put these pads on it and it sounded awesome! The perforations helped with reflections and lambskin also tamed the treble.
https://www.aliexpress.com/item/33057605882.html?spm=a2g0s.9042311.0.0.2abd4c4doMFnzp
This is a great post I am reposting here and hopefully more can be posted about these nice low cost pads !Oh so your doing something else on the driver itself? Interesting.
I need to get some.of that angel or unicorn hair for my T50'S, it's expensive stuff.
I was on the verge of selling the z7m2 and luckily these pads worked out and imo fixed most of the issues. I didn't go as far as opening up the unit as it appeared to have some kind of resin.
For some reason Joshua Valour said the pads weren't removable but they are once you remove the screw. These pads have a small lip which allows the ring to work. They are similar to Ori pads and really good quality.
I have a 110mm version on my vibrolab.
