Bernardas
- Dec 26, 2016
Oh and the range, will I be able to use them around my apartment?
The build quality seems okay but the hinge would break eventually I would imagine if your really rough with them. I listen to mine like 6 hours + each day but I always place them on my table. I'm not rough with them so I know they will last for me. Range seems okay. I haven't tested it far far but I left my phone in the kitchen and walked to the living room which is on the other side of the house ,didn't lose range.Oh and the range, will I be able to use them around my apartment?
Hi all!
I just purchased these headphones.
1. How do I know if Bass Boost is on when using AUX? No LED's are active when using wired connection.
1A. Does wired connection automatically turns on bass boost?
2. Blue tooth connection is NOT as loud or clear as wired. It's night and day. Wired, I get 40% (just a rough estimate) more sound and 70% more clearer sound.
2A. Can this be because priority is set to stable connection? I have three blue blinks when hitting power + up button.
hi guys, i got mine new 950bt 4days ago. loving its sound (without bass boost). but not happy with the muddy bass boost feature.
i have a doubt and i will be thankful if someone can clear it.
Music sound is loud and clear no problem in that but When i shake these headphones, the left side makes some noise like something is shaking inside. for example if i wear them and then jump and jump, while no song is playing, the left cane makes some sound. if i hold them and shake i can hear clearly the sound coming from left cane ( on which bass boost button is).
is it normal or my pair is faulty ? i ordered from snapdeal and i still can replace them for free if its faulty. can someone please guide ?
How much bass does the square piece of foam inserted into the exterior bass port block?
Not much in my opinion, you need to do internal damping mods and possibly plug the port with something less permeable. The drivers on these phones are bad tuned and even with most of BillP's mods they are bass heavy. I was a little concerned at first that I would over dampen them but I don't think that's the case. I need to open mine back up and do something more extensive so that the bass boost is more useful and so I can play something besides hip hop, rap and edm with these, particularly alternative or rock.
Got the fresh new another piece of 950bt. but it also rattles a little if i shake the left cup. well now it seems it is normal.
i am using it while jogging and it is not sweat-proof. so is there any sweat-proof ear pad cushions available out there for xb950bt ?
