Originally posted by redshifter
can someone help me get these worms vertigo spilled back in the can?
duncan:
i have the old a22l and a d-777 player like you. i actually liked that combo, although the bass got kinda of wooly after a while. can you tell me what the a44l are like with the d-777 (and no external amp, using the remote, with the d-777 volume turned up to between 6 & 8 and attenuated with the remote)? thanks, man. |
Okay, this is going to be slightly biased seeing that this is a lot
Quieter than i normally listen (at full volume on both unit and remote...)
The bass on the '44s isn't as thick as the '22s, whether there is less of it, or it is just better proportioned i cannot really comment... it is definetly crisper though
The midrange of the '44s is similar to that of the E888s (vs MX500s) it is very smooth, almost to the point of silkiness, whereas the 22s appear slightly colder (admittedly more like the sound i like) - The 44's appear more intimate
Treble, that is (to me) a slightly different story though... Where the 22s lay it all before you in a wide open expanse, the 44s appear quite closed in (also like the E888s) this adds to the feeling of warmth that these things create
Spacially, the 44s seem a lot more adept than the 22s at creating a soundstage, the 22s seem kinda closed in
Not necessarily better than the 22s, but a very different interpretation of the music,
almost although not quite to the same extremity as a E888 vs EX70 debate
I would strongly recommend that anyone who does get these 'phones should try Radioheads "Street Spirit [Fade Out]" from the album "The Bends"... The warmth and soundstage is uncanilly good
Against the E888s the A44s
almost have the same midrange warmth
BUT rightly or wrongly have a slightly sweeter top end!!
Bearing in mind, as Redshifter will all too happily tell you, the D777 is a cut above 95% of the competition on the PCDP market, so maybe my views are biased... Only your ears can decide!?
