https://www.sonarworks.com/reference/tutorials/studio-edition-manual
Enable Bass Boost and Tilt
Pg 33
Predefined Target Curves
Dry / wet control:
The Dry / Wet control lets you adjust the level of correction applied to the audio signal.Normally this should be set to 100% wet to ensure that the calibration is accurate. If you feelthat the correction is too drastic for your needs, tweak this to your liking, but keep in mind that the calibration will get increasingly less accurate. Note that this is not a typical Dry / Wetmixer - the knob controls the “depth” of the correction. The core signal is always Wet, but thecorrection amount can be dynamically adjusted.35
Pg 36
Zero Latency
Erm, I have tried both Reference 4 and True-Fi, not to mention I even looked at that. Have you not used these apps before? I.e. can you do more than fetch a link and list a few things? What did you find of significance in those features?
Might as well comment myself. Bass Boost is present in True-Fi and I think it's the same. The tilting is barbaric and gimmicky- you literally just tilt the whole frequency response around a point. The explanation for dry/wet states what it does- it reduces the effect of the equalization, nothing more. I played with the like two latency related options and found little difference among them. I highly doubt you'll find a solution to a general significant problem there. There are like two target curves if memory serves me right.
What am I missing?
