kevin gilmore
Señor Stax. Señor MAXX.
Can Jam '10 Organizer
- Jun 21, 2001
everyone quickly run out and buy a tice clock
sand is used for CPUs. therefore,
randomly spread sand on wires= micro computer!!!
I don't think that Ted Denney will mind me posting the PM below in it's entirety as he raises some very interesting points. Namely, that the HOT appears to be very headphone and equipment specific, which is something that potential purchasers should be aware of. Also, only certain headphone cables would appear to be compatible too, so this is another factor that should be accounted for.
Kudos to Ted for trying to extend the returns period, as he didn't known that it's already expired.
smial1966 I am not sure why the interaction of HOT in your system is muddling the sound but it is puzzling . I notice you listed the HD650 headphones in your report which to my ear, are a bit closed in sounding when compared directly to the headphones we used to voice HOT? Perhaps the HOT along with your electronics which I have not heard could be a less than synergistic combination? I also notice you have aftermarket headphone cables that I am not familiar with. Could it be your aftermarket headphone cables have a 'warming' effect on the sound which may not be compatible with the sonic signature of HOT? Perhaps you can try the HOT with the stock cables and see if this helps the situation out.
If you let me know which state side dealer you purchased your HOT from I will see to it personally that you are given enough time to experiment with HOT so that if you miss the window by a few days or even one week you will still get a full refund. I am also available to you should you want to discuss particular HOT to system / headphone interactions in Private Messages.
All the best,
Ted Denney
Lead Designer, Synergistic Research Inc
So by inference the HOT works best with the headphones that his device was voiced with ie hd800 and the lcd3 and with their cable provided?
When HOT is used with your favorite cans you hear sound that gets out of your head as well as smoother more articulate highs with improved bass.
And what user instructions literature is provided with the HOT (if you recall) ie is there mention of a 7day optimal run in etc?
If its uses are so limited, it makes me wonder how they can stand by this statement on the product page:
Should they amend this is include "(but only if your favorite cans sound like the HD800 or LCD-3 with the amps and cables we used)"?
Isn't the LCD-3 as dark i.e. "closed in" as the HD650?
Unless he removed it, the HOT unit I received from him didn't include any documentation. Just a box, some white synthetic cotton packing material and a white rubber band. And the HOT of course.
se
se
Steve,
You received exactly what I did. A box, packaging material and the HOT.
Perhaps the White rubber band needs to be deployed in the listening chain to experience audio nirvana?
I certainly hope not. It broke when I was putting it back on before packing it up and sending it out to my friend.
se
Well great, you've just invalidated all the measurements
