FallenAngel
If you're building a speaker amp, take a look at this beauty.
DIYCable.com : Intro » Home » Exodus/Hypex Amps » Amp Parts »
Originally Posted by pinkfloyd4ever /img/forum/go_quote.gif Much better selection than Avel too. And to add to what holland said, you can see their loaded voltages by clicking on the red link to each model's datasheet. |
Originally Posted by holland /img/forum/go_quote.gif to be fair, I had brought up the Antek during prototyping discussions and requested that it be added to the BOM. Upon further analysis and discussion, I had determined that it would be incapable of reaching the spec'd B+ and requested that it be removed. It was specifically the 0515 because due to the higher VA it would not dip as much in the voltage due to the lighter load in the default configuration. This was with the early HV multiplier/setup. While this would be OK for me, it would not be OK for a broad recommendation. In the default configuration with the standard load using the original HV setup, I was getting a B+ of about 58V (spec was a bit over 60V) which was about what I had calculated for loaded and about 59.x for unloaded which also matches what I had calculated. I have not tested it, nor done the math, for the existing HV setup. I have not tested it and probably would not recommend it for the higher current load configuration unless you can live with not having the highest of possible B+ voltages. One will have to decide for themselves what is acceptable or not. While this is not a big deal, and many probably won't even notice th voltages or not care, some will find it a big deal. |
Now that the 1st boards have been delivered (except here, but maybe tomorrow ), might it be a good idea to start a new topic Soha II builders blog? |
