Accurate (arguably), but potentially misleading. And I don't think you're doing it on purpose. But as I explained above, there are many here who expect different performance from a portable than from a desktop. It seems to me that is one of the "myths" the designer is interested in debunking; a laudable goal in my opinion. So for the purposes of the O2, unless someone corrects me, I believe the difference in the size of the enclosure is the only meaningful distinction between a desktop O2 and a portable O2. The real problem, as I see it, is that people are already trying to excuse potential performance issues by leaning on the old crutch of "but it's only a portable!" (And therefore any performance limitations compared to desktops should be excused.) My sole purpose in going on like this is that I would hope, when discussing performance, people would discuss the O2 as just an amp, the portable/desktop distinction is meaningless. Unless the designer is changing his tune, which his recent comment indicates might be the case.
What is the difference between a portable O2 and a desktop one? Good question! Other than the enclosure difference, the main one is the voltage present on the power supply rails. With AC Power connected, it is rated at 20Vpp. However, when no AC source is connected the dual 9-V batteries provide a rated 14Vpp to the power supply rails. One is kept from interfereing with the other through an
auctioneering mechanism so that when the wall power is connected only the mains power will be present on the rails, and when it is disconnected, only the battery power will be. The problem/design concern here is of course that it will output less power when on battery than connected to a wall. Now, with normal portable sources and not using obscenely hard to drive headphones this won't be a problem because most portables won't output as much voltage as a desktop source would. What do I mean by normal? Redbook standard is 2Vrms. Most portable sources are in the range from .5Vrms-1Vrms. Some in both catagory are over, however, they are the minority.
There are cases where a "hot source" (as it has been described) could overload the input stage if the gain is set too high. Of course, lowering the gain might be a problem if you are using a hot source with a hard to drive headphone. Again, for 99% of the people this won't be a problem. For the extra 1%, it is a possibility to use a higher voltage output wall transformer in conjunction with a higher voltage output battery (lion of some sort, for example) in conjunction with higher voltage MOSFETs (the ones in the design are limited to 25V) in order to rectify this. (You could also use a Zener clamp upstream of the MOSFETS)
The reason why this wasn't done in the original design was in order to keep the DIY as simple and safe as possible. Building a reliable lion power supply under DIY conditions would require surface mount soldering as well as certain safety features (CCCV shut-off for example); not to mention increased cost. This didn't meet the original design criteria as specified in his article and in the above.
Now you could argue that due to the lower power supply rails, this design isn't as one size fits all as the designer claims... and you would have a point. However, since independent measurements haven't been forthcoming the best realistic answer would be that, according to the designers measurements, for 99% of the people this amp would perform equally well in a desktop scenario as it would in a portable one. And for the outlier case, correct choice of differing gain structure/making some improvements to the power supply are available.
Some would also argue that the amp cannot output 20Vpp/14Vpp. However he has made measurements (on his website again) that clearly show the amp outputting a clear sine wave up to 20Vpp before it clips. That suggests the opamps specified (NJM2068s) can drive closer to the supply rails than the spec sheet lists. The designer has made many measurements/tests of many different opamps to arrive at the one he chose for the design. Again, until someone independently peer checks his results none of this is 100%.
Also, some in this thread are making the mistake of taking others assertions as the designers. I would be careful with that, he has enough written about this amp on his website (no one is banned from going there AFAIK) and on other forums to debate the merits or shortcomings of this amp for a while.
Hope this helps clear things up!
