ginetto61
Originally Posted by jeff7742
This article explains the benefits of parallel amplification, but too technical for me! Apparently, it can increase the SNR:
http://www.linear.com/solutions/5657
The only thing I know about the stock opamps is that they are dual channel. I assume the pin config is standard, whatever that is.
Hi and sorry but I am confused. I see just now that the 49990 is a single op-amp. It cannot be interchangeable with a dual OA. Completely different pins layout.
Instead the 49860 mentioned below is indeed a dual OA. How can they work in the same position ????
Maybe I am missing something ?
I am very impressed with the VA1's construction, especially the thick copper PCB (haven't seen that before), and how precisely everything is laid out.
The TRS and other connectors look high quality too.
Update: I put the old op amps back in and they sound good, but not as as good as mine. So most of the amp benefits I'm hearing i think are just due to amp break in - soundstage, etc.
The VMV DT/K opamps in the input stage still sound lifeless to me.
Maybe I should just break them in more, or maybe I should have gotten the HD version.
I tried 2 LME49860 in the input buffer, and that was big improvement. Very balanced sound, and they fit nicely with VMV opamps in the output stage. Just the right amount of bass too.
The LME49990 were the cleanest, but also the brightest, which some may not like.
Update: The VA1 continues to improve - soundstage, dynamics, everything. Using LME49860 in the input stage. This is a superb amp, and a joy to listen to.
I ordered several new opamps, including 2 OPA1612, 2 LME49720HA, and more LME49860's. I went back to the to the SAP-8 for a bit, and the sound was blurry in comparison, with a smaller soundstage. It's still a nice amp, but I have no use for it anymore
So the VA1 is clearly the top design. Please let me know which combinations of op-amps sound best.
However and again I do not understand why the 49990 works in the same position of a dual opamp.
Are you using an adapter that converts the pin configuration ?
Thanks again, gino
