Burson Audio has sent me a sample V5i for my honest review. I didn't compare them with the stock amps so I will do this here. And I will share further opinions about muses01 and stock opamps.
Firs I used V5i's in the input stage. I have tested them time to time for two weeks whilie burning in. They are really good opamps I can tell. They have better detail and clearness then muses01, being a little on the bright side but not harsh, and fast sound. They are producing percussions like sound excellent. But I think they are clipping the edges a little to do that. I compared it sound directly came out off may dac. And it seems they are faster then it is supposed to be. Imaging is better then muses01 too. Mids are a little dry to me. They both has excellent bass but muses01 goes just a little deeper. V5i has more tight bass
Muses01 was getting hot above %40-50 level. When they heat up they were messing the sound, by being muffled and distorted. V5i by the way giving their metal shield/heatsink they don't sweat even %60-70 level, so they they don't suffer like muses01 do.
I still prefer muses01 between two. It has more natural and warm sound. And I cant describe how but it has the "sweet" sound. But now this my preference is warm and darker sound.
After that trial I went back to muses01 in input stages and while I was back I wanted to try V5i's at the output stages. I only had two of them and they worked better even if without using the paralel amplification than stock opamps. The result was "wooow". Sound really became opened and much more alive. I usually listen rock with headphones but sometimes when I want to listen some bassy pop music I use my z623 2.1 speakers. Those speakers were a little back so not so much enjoyable. But with this combo they became so much alive I wanted to listen with them more. It had so much air and nice sparkle. But I mostly listen with my headphones and it was a little fatiguing for me. And lately I bought a new HD630VB which are a little on the bright side, they became more bright with this.
Then I returned to muses01 in the input stage and stock opamps at the output. Output stage stock opamps are a little laid back are more balanced and with the muses01 in the input they feel much natural. And since they are in warmer and darker area thats my taste. I dont think I will need to try any other opamp soon. I'm completely satisfied by the way for now. I still miss sometimes that nice lively sound on my z623 though.
Opamp and headphone match really matters as my experience show me. If you have a laidback gear a little bright opamp can make them shine. Or if you have bright warmer opamp takes away the fatiguing sound. SMSL VA1/DT stock input opamps were made for the bright beyer DT series headphones so they might have worked well with them. Actually those stock input opamps has better clearence, imaging and less distortion then the other two. But still they really lack bass and too lifeless.
EDIT: I'm just gonna post some pictures off them to show how they look for guide
