Originally Posted by jeff7742
I could take a picure, but it would only show new op amps I put in. The input buffer has the (2) LME49990 dip8 opamps. Actually the LME49990 is single channel, so there are 2 LME49990 chips soldered onto an adapter for each socket - you buy them from eBay that way.
http://www.ebay.com/itm/1PC-DUAL-SOIC-LME49990-OP-AMP-MODULE-DIP8-/201562948955?hash=item2eee16855b:g:A9QAAOSw6oBXEnVs
The LME49990 is a tough fit for many amps because of its current or power draw. I don't know the details, but I can say for sure it works well with both amps. It does get hot, but so do VMV's proprietary opamps. I just suggested heatsinks to be safe (I don't have them on mine yet),
Hi ! thanks a lot again for the very valuable advice.
Do you mean that the opamps used in the VA1 are made by SMSL Audio ? it sounds strange to me.
Are you sure ? and did you find any datasheet/specification about them ?
If you want to save money,
No money, up to a limit, is no object. I am willing to make some sacrifice for a nice sound. And I have already made others.
the LME49860 is good too, and much cheaper. But the LME49990 is best I've tried. The LME49990 is more powerful than the VMV opamps.
On the SAP-8, you turn up the volume less and it sounds really good. But its a good idea to use a powerful opamp in the output.
Yes. My feeling is that a more powerful part could be better at driving difficult loads. With more control also. But I could be exaggerating the issue. What I like of the sound of the SAP-8 is that is very spacious and natural. I like it very much driving my old but nice k501. I have even a weird idea. To gut it to make a line preamp with a very nice attenuator. I would be curious to listen to it. But it will take time to do it.
Replacing caps and transformers is beyond my goals right now. This amp sounds great already, and I'm sure will be even better after I replace all opamps.
It's the best resolving amp I've tried, and great for the money, and with opamps the whole character of the amp is changed. The price keeps dropping on Amazon, which makes me angry because its even cheaper than when I bought it.
Sorry now are you referring to the VA1 or the SAP-8 ? I have the sensation that the VA1 is even cleaner but a little flat and dry. But very very silent and of very robust construction. I like it. It seems like a brick. I like robust and massive cabinets. The feel they provide.
I don't know what you mean by marks cancelled, but op amps in the VA1 are VMV proprietary.
Obviously, they want to save money by making their own op amps, which are inferior to others out there.
This is strange to me because opamps bought in quantities are very cheap, even some good ones. But I trust you. It would be interesting to see at their datasheet.
They sound lifeless to me. I can tell you that the (2) input buffer ones are labeled "VMV DT/K". If you had the HD version, I assume it would be labeled "VMV HD".
The other (4) chips are labeled "VMV A6". When you replace these 4 chips, you should use the same opamp for all of them. The VA1 uses something called "parallel amplification", so 2 opamps work on one channel. I don't know how that works.
In my experience the lack of life sometime has to do more with some issue in the psu.
I followed a discussion once. A guy was saying that one problem with op-amps is that when asked to drive a tough load they need like 2x1000uF close to them to get some kind of energy reserve during the musical peaks. I bought his point.
In the VA1 close to the output opamps I can see only little plastic bypassing caps with very little uF (i.e. not energy stored/available locally for the op-amps). They are there for filtering maybe high Hz noise from the psu ?
I would try to add at least some 470uF of high quality from the +/- V to ground very close to the output opamps.
So when a musical peak comes the opamp will take the energy from these local caps and not from the ones located far away in the PSU.
Some amps design follows the same principle. You can see an example here, with many uF placed very close to the output devices.
http://img.aussieaudiomart.com/uploads/large/578788-mccormack_dna_1_deluxe_power_amp.jpg
But it is not very easy. I will try to do it. Some good quality caps like Nichicon or Panasonic for instance.
Thanks a lot again, gino
