StarTreker
- Jul 25, 2016
In my experience ordering online, equipment comes to you with the power cord required for your region. So if you ordered in the UK, I would expect it to be a UK plug. But doesn't the M200 use the same connection at the unit as the SP200 does, standard 3-pin computer cable? If so, even if it comes with the wrong cable, I am sure you have a UK plug that uses the standard computer 3-pin connection on the other end right?
